Home » Eclipse Projects » Eclipse 4 » [Solved] Eclipse e4 - No bundle loaded after exporting to exe
[Solved] Eclipse e4 - No bundle loaded after exporting to exe [message #1097791] Fri, 30 August 2013 06:51 Go to next message
ALex W is currently offline ALex WFriend
Member
I'm creating my application using Eclipse Juno.
In eclipse everything works well. I have my 6 or 7 bundle interacting correctly with each other within a custom eclipse e4 application.
I tried to export the main application as an exe file.
The exe file is generated, I can run it, but the problem is :
I only have the main application. My bundles (weither they are contributing to the UI or not) doesn't start.
So I went and look inside the plugins folder of the exported app. I does not contain my custom bundle. I tried to manually copy them inside the directory, but no better.
Should I modify the config.ini in the configuration folder ?
Is there any trick to export those in eclipse.
Please note, that I don't want to add these bundles in the required-bundle because they definitely are not required.
Any advice ?
[Updated on: Wed, 25 September 2013 21:17]
Report message to a moderator
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1097862 is a reply to message #1097791] Fri, 30 August 2013 08:58 Go to previous messageGo to next message
Jonas Helming is currently offline Jonas HelmingFriend
How did you build your product?
Am 30.08.2013 08:51, schrieb ALex W:
> Hello,
> Any advice ?
> Thanks
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1097883 is a reply to message #1097791] Fri, 30 August 2013 09:30 Go to previous messageGo to next message
Member
I used the features in eclipse. Exporting using the product file of my main application (export wizard if I recall the name correctly).
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1099770 is a reply to message #1097883] Mon, 02 September 2013 07:21 Go to previous messageGo to next message
Have you added your custom bundle to the product? Have you validated
your product configuration?
Am 30.08.2013 11:30, schrieb ALex W:
> Hello,
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1100119 is a reply to message #1099770] Mon, 02 September 2013 18:01 Go to previous messageGo to next message
Member
I'm not sure what you mean.
- My bundles are listed in the run configuration.
- They are not in the product dependencies, since I can't make them required.
Everything goes well in eclipse, not when exported... I can't see the eclipse custom parts or menu...
The customs bundles are listed in my config.ini, and present in the plugins directory.
There is no log file in the workspace directory...
Is there any way to add them as optional plugins or something ?
thanks
[Updated on: Mon, 02 September 2013 18:18]
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1100143 is a reply to message #1100119] Mon, 02 September 2013 18:52 Go to previous messageGo to next message
Member
Ok I'm moving forward. I just realize that there is 2 buttons in the product dependencies "Add" and "Add required"... It seems to be working now.
I'm still having some ClassNotFound issues. I probably have to export bin folder in the build
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1100149 is a reply to message #1100143] Mon, 02 September 2013 19:01 Go to previous messageGo to next message
Member
Ok... adding the bin to the export int the build.properties didn't solve the issue. Any idea ?
My fragments are loaded properly because I can see the new tabs in the Partstack.
I also checked by unzipping the Jar file which was giving the ClassNotFound exception, and the class is inside.
[Updated on: Mon, 02 September 2013 19:14]
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1100609 is a reply to message #1100149] Tue, 03 September 2013 10:38 Go to previous messageGo to next message
Which classes cannot be found?
Am 02.09.2013 21:01, schrieb ALex W:
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1100830 is a reply to message #1100609] Tue, 03 September 2013 16:59 Go to previous messageGo to next message
Member
A custom class defining an eclipse Part. A simple Pojo class actually...
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1101534 is a reply to message #1100830] Wed, 04 September 2013 15:25 Go to previous messageGo to next message
Have you exported into a completly empty folder?
Does it work when you start from the IDE?
Am 03.09.2013 18:59, schrieb ALex W:
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1101739 is a reply to message #1101534] Wed, 04 September 2013 22:27 Go to previous messageGo to next message
Member
Yes, I exported to a completely empty folder.
Evertyhing works well in the IDE.
My plugin has the option "Activate this plug-in when one of its classes is loaded" selected. So I'm not sure why it doesn't work...
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1101750 is a reply to message #1101739] Wed, 04 September 2013 22:50 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Upper vs lower case if you are on win32? In the IDE stuff is loaded from
the filesystem and freaking windows has not upper/lowercase support
whereas when loading from a jar upper/lower matter.
Tom
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1101751 is a reply to message #1101750] Wed, 04 September 2013 22:52 Go to previous messageGo to next message
you can also launch with -console -noexit and see what you can find out
at the OSGi-Console.
Tom
> Tom
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1102004 is a reply to message #1101751] Thu, 05 September 2013 08:06 Go to previous messageGo to next message
I think ANT on windows has also problems with whitespaces, either in the
eclipse path or in the workspace path
Am 05.09.2013 00:52, schrieb Tom Schindl:
> Tom
>> Tom
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1102034 is a reply to message #1102004] Thu, 05 September 2013 09:06 Go to previous messageGo to next message
Member
I will check your suggestion as soon as possible and let you know.
Re: Eclipse e4 - No bundle loaded after exporting to exe [message #1116798 is a reply to message #1102034] Wed, 25 September 2013 21:15 Go to previous message
Member
Just to you know I found the solution.
Every project for my bundles had 2 separates source folder : src and ui.
At export, src was exported, but not ui. That why I had the java.lang.ClassNotFoundException.
To solve this, I had to add the following entry in the build.properties :
source.. = src/,\
           ui/
And it now works great.
Previous Topic:Create product with resources
Next Topic:e4 compat layer and programmatic Action contributions.
Current Time: Tue Apr 16 06:40:20 GMT 2024
Powered by FUDForum. Page generated in 0.19978 seconds
