Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Warning in query implemented in Java
icon4.gif  [Acceleo] Warning in query implemented in Java [message #1096513] Wed, 28 August 2013 13:38 Go to next message
Johan Hardy is currently offline Johan HardyFriend
Member
Dear All,
I'm facing at repetitive warnings wrt a simple Acceleo query. The problem is that the warnings are listed in the error log view of Eclipse. And the list becomes longer and longer each time I perform a new generation.
Here is the simple query I use to format comments in C:
[query public formatComment(arg0 : String, arg1 : String, arg2 : String, arg3 : Integer) : String
	= invoke('com.spacebel.acceleo.uml.to.c.services.commonServices', 'formatComment(java.lang.String, java.lang.String, java.lang.String, int)', Sequence{arg0, arg1, arg2, arg3}) /]
The associated java method is the following:
public String formatComment(String comment, String tagLine, String startLine, int lineSize)
		String result = tagLine;
		String[] yy = comment.replaceAll("\\r","").split("\n");
		for (int i=0; i<yy.length; i++)
			String line = yy[i];
			if (i!=0)
				result = result + "\n" + startLine;
			if ((line.indexOf("@image") >= 0) || (line.length() <= lineSize))
				result = result + line;
			else
				int size = 0;
				String[] tokens = line.split(" ");
				for (int x=0; x<tokens.length; x++)
					String self = tokens[x];
					if ((self.length() + size) < lineSize)
						size = size + 1 + self.length();
						result = result + self;
					else
						size = self.length() + 1;
						result = result + "\n" + startLine + self;
					if ((self.length() == 0) || (!self.endsWith("\n")))
						result = result + " ";
		return result;
The warning I have is: "It is strongly recommended not to return directly a String from a Java service in a query taking a primitive as its first parameter in order to ensure the precision of the traceability of each text region generated."
Does anyone know how to eliminate (kill) it ?
Regards;
[Updated on: Wed, 28 August 2013 13:38]
Report message to a moderator
Re: [Acceleo] [message #1096574 is a reply to message #1096513] Wed, 28 August 2013 15:26 Go to previous messageGo to next message
Add an extra argument to your query so that it has on EObject to hang on to.
Just delete the irritations in the Problem View.
Ed Willink
On 28/08/2013 14:38, Johan Hardy wrote:
> Dear All,
> new generation.
> if (i!=0) {
> lineSize))
> else
> int size = 0;
> else
> (!self.endsWith("\n"))) {
> result = result + "\n" + startLine; return result;
> Regards;
Re: [Acceleo] [message #1096691 is a reply to message #1096574] Wed, 28 August 2013 18:34 Go to previous message
Member
Hi Ed,
Many thanks for your prompt answer. I used en EObject and it works !
[query public formatComment(arg0 : uml::Comment, arg1 : String, arg2 : String, arg3 : Integer) : String
	= invoke('com.spacebel.acceleo.uml.to.c.services.commonServices', 'formatComment(org.eclipse.uml2.uml.Comment, java.lang.String, java.lang.String, int)', Sequence{arg0, arg1, arg2, arg3}) /]
Regards;
Previous Topic:[Acceleo] How to get the value of a property (tagged value)
Next Topic:[Xpand] Hiding Xpand template from user
Current Time: Mon Oct 25 08:58:58 GMT 2021
Powered by FUDForum. Page generated in 0.01575 seconds
