ReadOnly mapping attribute causes inserts [message #1095732] |
Tue, 27 August 2013 12:55 |
Roger Spall Messages: 17 Registered: January 2013 |
I have a specific (and simplified) design that is leaving me scratching my head:
An Address object has a 1-1 relation with a Province
<entity class="com.yamaha.progress.model.domain.bank.Province" access="FIELD">
<table name="TST_PROVINCE"/>
<attributes>
<id name="oid">
<column name="OID"/>
<generated-value generator="MASTER_SEQ" strategy="SEQUENCE"/>
<sequence-generator allocation-size="1" name="MASTER_SEQ" sequence-name="MASTER_SEQ"/>
</id>
<basic name="code">
<column name="code"/>
</basic>
<basic name="name">
<column name="name"/>
</basic>
</attributes>
</entity>
<entity class="com.yamaha.progress.model.domain.bank.Address" access="FIELD">
<table name="TST_ADDRESS"/>
<attributes>
<id name="oid">
</id>
<basic name="street">
<column name="street"/>
</basic>
<basic name="street2">
<column name="street2"/>
</basic>
<basic name="city">
<column name="city"/>
</basic>
<one-to-one name="province" fetch="LAZY" target-entity="com.yamaha.progress.model.domain.bank.Province">
<join-column name="PROVINCE_OID"/>
<cascade>
<cascade-persist/>
</cascade>
</one-to-one>
</attributes>
</entity>
Next I have a simple Stateless Session Bean method
@Stateless
@LocalBean
@TransactionManagement(TransactionManagementType.CONTAINER)
@TransactionAttribute(TransactionAttributeType.REQUIRED)
public class BankManagerBean {
public Address createAddress(String street, String street2, String city, Province province) {
Province matchingProvince = em.find(Province.class, province.getOid());
Address newAddress = new Address(street, street2, city, matchingProvince);
em.persist(newAddress);
return newAddress;
When I call this method, everything works fine (no surprises!).
Now, when I mark the Province mapping as ReadOnly and try the same Session Bean method again, Eclipselink tries to insert a Province - and my database correctly prevents a duplicate record and an exception is thrown:
becomes
<entity class="com.yamaha.progress.model.domain.bank.Province" access="FIELD" read-only="true">
Stack trace:
[8/27/13 8:43:45:745 EDT] 00000030 SystemOut O [EL Warning]: 2013-08-27 08:43:45.745--UnitOfWork(-2126259708)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.ibm.websphere.ce.cm.DuplicateKeyException: ORA-00001: unique constraint (TRN_ADMIN.TST_PROVINCE_PK) violated
Error Code: 1
Call: INSERT INTO TST_PROVINCE (OID, code, name) VALUES (?, ?, ?)
bind => [2, MAN, Manitoba]
Query: WriteObjectQuery(com.yamaha.progress.model.domain.bank.Province@c6ff4f37)
[8/27/13 8:43:45:746 EDT] 00000030 RegisteredSyn E WTRN0074E: Exception caught from before_completion synchronization operation: javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl$1.handleException(EntityManagerSetupImpl.java:692)
at org.eclipse.persistence.transaction.AbstractSynchronizationListener.handleException(AbstractSynchronizationListener.java:275)
at org.eclipse.persistence.transaction.AbstractSynchronizationListener.beforeCompletion(AbstractSynchronizationListener.java:170)
at org.eclipse.persistence.transaction.JTASynchronizationListener.beforeCompletion(JTASynchronizationListener.java:68)
at com.ibm.tx.jta.impl.RegisteredSyncs.coreDistributeBefore(RegisteredSyncs.java:291)
at com.ibm.ws.tx.jta.RegisteredSyncs.distributeBefore(RegisteredSyncs.java:152)
at com.ibm.ws.tx.jta.TransactionImpl.prePrepare(TransactionImpl.java:2338)
at com.ibm.ws.tx.jta.TransactionImpl.stage1CommitProcessing(TransactionImpl.java:557)
at com.ibm.tx.jta.impl.TransactionImpl.processCommit(TransactionImpl.java:1015)
at com.ibm.tx.jta.impl.TransactionImpl.commit(TransactionImpl.java:949)
at com.ibm.ws.tx.jta.TranManagerImpl.commit(TranManagerImpl.java:438)
at com.ibm.tx.jta.impl.TranManagerSet.commit(TranManagerSet.java:181)
at com.ibm.ejs.csi.TranStrategy.commit(TranStrategy.java:950)
at com.ibm.ejs.csi.TranStrategy.postInvoke(TranStrategy.java:265)
at com.ibm.ejs.csi.TransactionControlImpl.postInvoke(TransactionControlImpl.java:579)
at com.ibm.ejs.container.EJSContainer.postInvoke(EJSContainer.java:4873)
at com.yamaha.progress.apps.bank.EJSLocalNSLBankManagerBean_a9ecdbb0.createAddress(EJSLocalNSLBankManagerBean_a9ecdbb0.java)
at com.yamaha.admin.jpamigration.BankTest.testCreateAddress(BankTest.java:79)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
My client has marked a lot of their mappings as read-only as a way of identifying certain objects which should never change - the classes themselves have no setter methods either, with just an empty constructor plus one constructor which takes an oid.
What am I missing with respect to the semantics of 'read-only'?
FUDForum. Page generated in 0.03787 seconds
