Re: Regarding jubula recoding problem [message #1097839 is a reply to message #1097779] |
Fri, 30 August 2013 08:18 |
Manoj Kumar Rout Messages: 3 Registered: August 2013 |
hi
Thanks Alex for reply.That problem is solved.Actually i am new to this jubula.now i am trying with recording and some modifications in that test case. so i want to know that which scripting language it supports and how to use that?could you please help me in this by providing some better example apart from those basic examples like adder etc.And can we use python scripting language
[Updated on: Fri, 30 August 2013 08:53] Report message to a moderator
Re: Regarding jubula recoding problem [message #1099680 is a reply to message #1097893] |
Mon, 02 September 2013 04:00 |
hi alex
Thanks for those information.that really helped me a lot.But here my problem is i am trying to generate the code by DAVE tool using jubula.But after generating the code in DAVE tool i want to validate the generated value in code with the value i am giving in excel sheet as input.so for comparision of that how can i get the value from code to jubula tool so that i can compare with excel sheet value?
for example i have added some snap shots.
here i want to validate the baud rate that generated by DAVE tool with the baud rate that i am giving in excel sheet as input.
so please help me in this.
thanks
[Updated on: Mon, 02 September 2013 06:49] Report message to a moderator
FUDForum. Page generated in 0.02877 seconds
