Home » Archived » BIRT » Concatenate Show All Values
Concatenate Show All Values [message #1094812] Mon, 26 August 2013 08:14 Go to next message
Marina Orth is currently offline Marina OrthFriend
Member
i want to concatenate some values. I'm using aggregation Concatenate. If "Show all values" is blank, the result contains only unique values. If "show all values" is true, the result is blank. But i want to see duplicates. Is this a bug?
Re: Concatenate Show All Values [message #1095879 is a reply to message #1094812] Tue, 27 August 2013 17:10 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
If you also set the "Max length" to 100 or whatever, then all values will show, even repeats.
Michael
Developer Evangelist, Silanis
Re: Concatenate Show All Values [message #1097976 is a reply to message #1095879] Fri, 30 August 2013 12:21 Go to previous messageGo to next message
Member
Ok, thanks
Re: Concatenate Show All Values [message #1098043 is a reply to message #1097976] Fri, 30 August 2013 14:23 Go to previous message
Not a problem! Let me know if you run into further issues with this.
Michael
Previous Topic:Birt 4.3 docx whitespace problem
Next Topic:help with "Chart Builder Example"
Current Time: Fri Sep 22 02:58:51 GMT 2023
Powered by FUDForum. Page generated in 0.02773 seconds
