Home » Archived » MOFScript » call a java method from a transformation
call a java method from a transformation [message #1092929] Fri, 23 August 2013 10:45 Go to next message
beaperez Mising name is currently offline beaperez Mising nameFriend
Member
Hello!
I am trying to invoke a java method from a transformation.
The java class (plugin.JavaClass) is in the directory:
JavaProject/src/plugin/JavaClass.java
with the simple code:
package plugin;
class JavaClass{
public String example(){
return "Hello";
and the MOFScript transformation in:
JavaProject/src/plugin/transformations/transformation.m2t
I am using the code:
hello= java ("plugin.JavaClass", "example", null, "C:/Program Files/Java/jre7/")
But I get an "Java Class not found" error.
Does anybody know where is the problem?
Thank you very much in advance
Bea
Re: call a java method from a transformation [message #1099813 is a reply to message #1092929] Mon, 02 September 2013 08:45 Go to previous message
Member
The problem was the classpath...I have used the path to the "bin" folder of the used Eclipse project (for example C:/eclipse/workspace/MyProject/bin/, and it works.
Previous Topic:call a java method from a transformation
Next Topic:Input parameters in a transformation
Current Time: Wed Dec 02 10:51:31 GMT 2020
Powered by FUDForum. Page generated in 0.01361 seconds
