JAXB : EclipseLink-3002 while unmarshalling xml even JAXB RI works [message #1092853] |
Fri, 23 August 2013 09:03 |
Arnaud MERGEY Messages: 243 Registered: March 2010 Location: France |
Hello, sorry for the new post, for some reasons, replying to previous does not work
After more tests, I am probably facing a bug that has been fixed, becauseI cannot reproduce the issue with eclipselink 2.5.0.
The thing is I am stuck with 2.3.2 currently because my code is supposed to run in weblogic 12c that expose eclipselink 2.3.2 as JAXB provider, so I am wondering if there is any way to workaround this issue by some anotations or some properties
I attach a sample project, with the xsd I used to generate classes with and a xml file.
To reproduce the issue, you have to copied eclipselink.jar in lib (too big to be attached with)
launcher launch reproduces the issue.
Best Regards,
Arnaud
FUDForum. Page generated in 0.03035 seconds
