Re: The alias '/rwt-resources' is already in use. [message #1091409 is a reply to message #1091355] |
Wed, 21 August 2013 13:14 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Rene,
please attach your plugin.xml (where entrypoints/application extensions
are specified). Do you have second application registered on the same
servlet path?
Best,
Ivan
On 8/21/2013 2:49 PM, Rene Richter wrote:
> Hey,
> I'm running into the error message, shown in the title when launching
> an emf editor in RAP.
> The problem is reproducible quite easily:
> Im running Eclipse Kepler with RAP 2.1. An EntryPoint Extension,
> pointing to my IApplication implementation is added to the manifest
> and the launch configuration is just adjusted in terms of the servlet
> path (e.g. EntryPointPath?startup=ApplicationID)
> Attempts to solve this problem:
> - It seems that the most simple solution is to set a custom
> contextPath in the launch configuration. But that doesn't show any
> effect.
> - The RAP/FAQ suggest a simple solution under 5.3. Unfortunately I
> don't know whether I am doing something wrong, but the application
> configuration seems to be called long after the error is thrown.
> For both solutions, the contextName is null when debugging the
> ApplicationLauncherImpl.
> Can anyone reproduce this problem?
> I would appreciate any help and thank you in advance.
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03741 seconds
