Home » Eclipse Projects » Eclipse 4 » MPart contribution to Outline view and Properties view
MPart contribution to Outline view and Properties view [message #1091005] Tue, 20 August 2013 23:55 Go to next message
Jakub Czerny is currently offline Jakub CzernyFriend
I develop an Eclipse plugin intended to tun in Eclipse IDE. I want my MPart to contribute (define custom content) to standard Outline and Properties view.
How can I achieve that?
Thanks for advice.
Jakub
Re: MPart contribution to Outline view and Properties view [message #1092441 is a reply to message #1091005] Thu, 22 August 2013 20:08 Go to previous messageGo to next message
Eric Moffatt is currently offline Eric MoffattFriend
You should look into the documentation on extenging a PageBookView (which both of these views are). Essentially a PageBookView allows you to contribute a 'page' but I've never actually done any work here. You will likely find a lot of info about adding a specific Outline page for an editor...
Re: MPart contribution to Outline view and Properties view [message #1092498 is a reply to message #1092441] Thu, 22 August 2013 22:01 Go to previous messageGo to next message
Thank you for your answer.
However below attached stacktrace (execution paused when JavaEditor class is asked for adapter of class IContentOutlinePage) shows that class PageBookView is called from org.eclipse.ui.internal.WorkbenchPage$15 (7th and 8th entries). Both of these classes are part of standard (non-e4) eclipse.
I'm looking for some way, how my custom MPart can provide its implementation of IContentOutlinePage.
Thread [main] (Suspended (entry into method getAdapter in org.eclipse.jdt.internal.ui.javaeditor.JavaEditor))
	org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor(org.eclipse.jdt.internal.ui.javaeditor.JavaEditor).getAdapter(java.lang.Class) line: 2199
	org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor.getAdapter(java.lang.Class) line: 1779
	org.eclipse.ui.internal.views.ViewsPlugin.getAdapter(java.lang.Object, java.lang.Class, boolean) line: 103
	org.eclipse.ui.views.contentoutline.ContentOutline.doCreatePage(org.eclipse.ui.IWorkbenchPart) line: 131
	org.eclipse.ui.views.contentoutline.ContentOutline(org.eclipse.ui.part.PageBookView).createPage(org.eclipse.ui.IWorkbenchPart) line: 411
	org.eclipse.ui.views.contentoutline.ContentOutline(org.eclipse.ui.part.PageBookView).partActivated(org.eclipse.ui.IWorkbenchPart) line: 754
	org.eclipse.ui.part.PageBookView$4.partActivated(org.eclipse.ui.IWorkbenchPartReference) line: 1044
	org.eclipse.ui.internal.WorkbenchPage$15.run() line: 4798
	org.eclipse.core.runtime.SafeRunner.run(org.eclipse.core.runtime.ISafeRunnable) line: 42
	org.eclipse.ui.internal.WorkbenchPage.firePartActivated(org.eclipse.e4.ui.model.application.ui.basic.MPart) line: 4796
	org.eclipse.ui.internal.WorkbenchPage.access$16(org.eclipse.ui.internal.WorkbenchPage, org.eclipse.e4.ui.model.application.ui.basic.MPart) line: 4776
	org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(org.eclipse.e4.ui.model.application.ui.basic.MPart) line: 195
	org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run() line: 183
	org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(org.eclipse.e4.ui.model.application.ui.basic.MPart) line: 181
	org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(org.eclipse.e4.ui.model.application.ui.basic.MPart, boolean, boolean) line: 595
	org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(org.eclipse.e4.ui.model.application.ui.basic.MPart, boolean) line: 539
	org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer(org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer).activate(org.eclipse.e4.ui.model.application.ui.basic.MPart) line: 104
	org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(org.eclipse.swt.widgets.Event) line: 59
	org.eclipse.swt.widgets.EventTable.sendEvent(org.eclipse.swt.widgets.Event) line: 84
	org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2(org.eclipse.swt.widgets.Widget).sendEvent(org.eclipse.swt.widgets.Event) line: 1392
	org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2(org.eclipse.swt.widgets.Widget).sendEvent(int, org.eclipse.swt.widgets.Event, boolean) line: 1416
	org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2(org.eclipse.swt.widgets.Widget).sendEvent(int, org.eclipse.swt.widgets.Event) line: 1401
	org.eclipse.swt.widgets.Shell.setActiveControl(org.eclipse.swt.widgets.Control, int) line: 1675
	org.eclipse.swt.custom.StyledText(org.eclipse.swt.widgets.Control).gtk_button_press_event(long, long, boolean) line: 3004
	org.eclipse.swt.custom.StyledText(org.eclipse.swt.widgets.Control).gtk_button_press_event(long, long) line: 2940
	org.eclipse.swt.custom.StyledText(org.eclipse.swt.widgets.Composite).gtk_button_press_event(long, long) line: 706
	org.eclipse.swt.custom.StyledText(org.eclipse.swt.widgets.Canvas).gtk_button_press_event(long, long) line: 152
	org.eclipse.swt.custom.StyledText(org.eclipse.swt.widgets.Widget).windowProc(long, long, long) line: 2078
	org.eclipse.swt.custom.StyledText(org.eclipse.swt.widgets.Control).windowProc(long, long, long) line: 5467
	org.eclipse.swt.widgets.Display.windowProc(long, long, long) line: 4569
	org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(long) line: not available [native method]
	org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(long) line: 8707
	org.eclipse.swt.widgets.Display.eventProc(long, long) line: 1243
	org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(long, boolean) line: not available [native method]
	org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(long, boolean) line: 2287
	org.eclipse.swt.widgets.Display.readAndDispatch() line: 3361
	org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run() line: 1113
	org.eclipse.core.databinding.observable.Realm.runWithDefault(org.eclipse.core.databinding.observable.Realm, java.lang.Runnable) line: 331
	org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(org.eclipse.e4.ui.model.application.MApplicationElement, org.eclipse.e4.core.contexts.IEclipseContext) line: 997
	org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(org.eclipse.e4.ui.model.application.MApplicationElement) line: 138
	org.eclipse.ui.internal.Workbench$5.run() line: 610
	org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org.eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) line: 567
	org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) line: 150
	org.eclipse.ui.internal.ide.application.IDEApplication.start(org.eclipse.equinox.app.IApplicationContext) line: 124
	org.eclipse.equinox.internal.app.EclipseAppHandle.run(java.lang.Object) line: 196
	org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(java.lang.Object) line: 110
	org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(java.lang.Object) line: 79
	org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lang.Object) line: 354
	org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lang.String[], java.lang.Runnable) line: 181
	sun.reflect.NativeMethodAccessorImpl.invoke0(java.lang.reflect.Method, java.lang.Object, java.lang.Object[]) line: not available [native method]
	sun.reflect.NativeMethodAccessorImpl.invoke(java.lang.Object, java.lang.Object[]) line: 57
	sun.reflect.DelegatingMethodAccessorImpl.invoke(java.lang.Object, java.lang.Object[]) line: 43
	java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object...) line: 606
	org.eclipse.equinox.launcher.Main.invokeFramework(java.lang.String[], java.net.URL[]) line: 636
	org.eclipse.equinox.launcher.Main.basicRun(java.lang.String[]) line: 591
	org.eclipse.equinox.launcher.Main.run(java.lang.String[]) line: 1450
	org.eclipse.equinox.launcher.Main.main(java.lang.String[]) line: 1426
Re: MPart contribution to Outline view and Properties view [message #1092952 is a reply to message #1092498] Fri, 23 August 2013 11:15 Go to previous message
Andrzej Szczepanski is currently offline Andrzej SzczepanskiFriend
Bad news: Outline and Properties views, together with interfaces needed to contribute to them, all belong to org.eclipse.ui(...) plug-in(s), so it is not possible at the moment with pure Eclipse4. Or at least that is what I was lead to believe.
If you haven't already, check out Tom Schindl's e4bridge:
http://tomsondev.bestsolution.at/2011/06/10/how-to-apply-the-e4-programming-model-to-3-x/
In my project I've followed this approach. I have my editor implemented in pure E4 (it is a part of pure E4 RCP product), but I also have this, sort-of "adapter" plug-in where I implement DIEditorPart, that wraps over my editor and allows me to reuse it as contribution to Eclipse IDE.
public class WrapperEditor extends DIEditorPart<MyE4EditorPart> {
    /* and as you already know, you can contruibute to Outline
     * like that */
    public Object getAdapter(Class adapter) {
        if (adapter.equals(IContentOutlinePage.class)) {
            return new ContentOutlinePage() {
        return super.getAdapter(adapter);
Of course, your case may be different, so you may chose different approach than e4-bridge (like using Comaptibility layer or stuff...).
Previous Topic:Advice for Kepler based Product
Next Topic:PropertyDialog for e4 app
Current Time: Wed Apr 08 19:29:43 GMT 2020
Powered by FUDForum. Page generated in 0.02866 seconds
