Duplicate Name and Signature [message #1090119] |
Mon, 19 August 2013 14:38  |
I am getting
"java.lang.ClassFormatError: Duplicate field name&signature in class file "
error while trying to compile and run a aspect in my web project through Maven. However, it works fine if I compile and run through eclipse IDE using ADJT. I am using AspectJ 1.7.0.
My Pom.xml has been configured as below:
<build>
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<executions>
<execution>
<!-- Modifying output directory of default compile because non-weaved
classes must be stored in separate folder to not confuse ajc by reweaving
already woven classes (which leads to to ajc error message like "bad weaverState.Kind:
-115") -->
<id>default-compile</id>
<configuration>
<compilerArguments>
<d>WebContent/unwoven-classes</d>
</compilerArguments>
</configuration>
</execution>
</executions>
</plugin>
<!-- AspectJ plugin -->
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>aspectj-maven-plugin</artifactId>
<version>1.4</version>
<configuration>
<showWeaveInfo>true</showWeaveInfo>
<complianceLevel>1.6</complianceLevel>
<source>1.6</source>
<target>1.6</target>
<weaveDirectories>
<weaveDirectory>WebContent/unwoven-classes</weaveDirectory>
</weaveDirectories>
<sources>
<source>
<basedir>src</basedir>
<includes>
<include>**/QueryProfilerAspect.java</include>
</includes>
</source>
</sources>
</configuration>
<dependencies>
<dependency>
<groupId>org.aspectj</groupId>
<artifactId>aspectjrt</artifactId>
<version>${org.aspectj.version}</version>
</dependency>
<dependency>
<artifactId>aspectjtools</artifactId>
<scope>compile</scope>
</dependency>
</dependencies>
<executions>
<execution>
<!-- Compile and weave aspects after all classes compiled by javac -->
<phase>process-classes</phase>
<goals>
<goal>compile</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
Any idea what may be going wrong in here?
FUDForum. Page generated in 0.05261 seconds
