ckeditor Custom Widget example - JS unpacked [message #1089983] |
Mon, 19 August 2013 14:50 |
Is there a SIMPLE example of a Custom Widget using RemoteAPI somewhere?
I've tried to use CKEditor, which is great, and it works just fine, but the JS for this is overcomplex as a basic example.
The GoogleMaps example from older API seems straight-forward, but there is no RemoteAPI version of this yet as far as I can see? (did I miss it somewhere?)
If I am to persevere with CKEditor, is there an unpacked copy of the ckeditor.js that I can use for reference?
Or even better, a 'how to' guide, like there was for the old GoogleMaps control before RemoteAPI came along?
Thanks, John
Just because you can doesn't mean you should
Re: ckeditor Custom Widget example - JS unpacked [message #1090001 is a reply to message #1089983] |
Mon, 19 August 2013 15:11 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi John,
Tim started a Wiki here: http://wiki.eclipse.org/RAP/Custom_Widgets_FAQ
We will extend it over time.
Best,
Ivan
> miss it somewhere?)
> Thanks, John
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.05124 seconds
