formatting a ICompilationUnit in a plugin. [message #162552] |
Thu, 03 June 2004 15:33 |
Originally posted by: gbforum.laposte.net
I want inside my plugin to automaticaly apply code formating on a
ICompilationUnit. Some thing like :
ICompilationUnit cu;
CodeFormatter cformatter = new DefaultCodeFormatter();
TextEdit te = cformatter.format(CodeFormatter.K_COMPILATION_UNIT,
cu.getSource(), cu.getSourceRange().getOffset(),
cu.getSourceRange().getLength(), /* indentation level */0,
BeautifyEntries.EOL );
te.apply(cu); // <- this is what does not exist . how do I re insuflate
the modeification into the ICompilationUnit.
Thanks in advance.
Guillaume
Re: formatting a ICompilationUnit in a plugin. [message #162569 is a reply to message #162552] |
Thu, 03 June 2004 16:12 |
Originally posted by: olivier_thomannNO.ca.ibm.comSPAM
Le Thu, 3 Jun 2004 15:33:42 +0000 (UTC), gbforum@laposte.net
This is not good. This is not API.
The right way to create a code formatter is:
CodeFormatter cFormatter =
org.eclipse.jdt.core.ToolFactory.createCodeFormatter(JavaCor e.getOptions());
// you can set the options you want there
DefaultCodeFormatter is inside an package with "internal" in its name.
You should NEVER call directly such classes. They might be removed,
renamed or changed without any notice since they are not API.
You need to use a org.eclipse.jface.text.Document. Then you use:
te.apply(myDocument);
Hope this help,
Olivier
Re: formatting a ICompilationUnit in a plugin. [message #162684 is a reply to message #162569] |
Fri, 04 June 2004 06:37 |
oups. ok Thanks for that correction.
I know that I need to use a IDocument my question is how I made the link
between my ICompilationUnit and my IDocument ?
in fact my ICompilationUnit is a WorkingCopy of a compilation unit. I want
To format the source in it, and then commit the WorkingCopy.
I have the impression that I can copy the content of my workingCopy into a
IDocument but that will be only a copy of String. not a reference that
makes any modification to the IDocument be reported to the
ICompilationUnit. Am I wrong ?
Thanks for the answer,
Guillaume
Re: formatting a ICompilationUnit in a plugin. [message #162752 is a reply to message #162684] |
Fri, 04 June 2004 13:51 |
Le Fri, 4 Jun 2004 06:37:33 +0000 (UTC), gbforum@laposte.net
Not sure. If you create the document with the contents of your working
copy and after you applied the edits, you copy back the contents of
the document into the working copy and then you commit it should work
fine.
Olivier
Re: formatting a ICompilationUnit in a plugin. [message #162798 is a reply to message #162752] |
Fri, 04 June 2004 14:46 |
> fine.
It should that the magique of copying back the contents of the document
into the compilation unit that I don't know how to do.
Re: formatting a ICompilationUnit in a plugin. [message #162806 is a reply to message #162798] |
Fri, 04 June 2004 15:09 |
Le Fri, 4 Jun 2004 14:46:29 +0000 (UTC), gbforum@laposte.net
Did you try this?
compilationUnit.getBuffer().setContents(myDocument.get());
Olivier
FUDForum. Page generated in 0.02149 seconds
