Contributing tabs and sections to the WSDL Editor [message #162440] |
Tue, 28 February 2006 14:19 |
I am currently using the org.eclipse.wst.wsdl.ui.internalEditorExtensions
extension point to contribute sections to the WSDL Editor from an external
plugin. I also tried contributing tabs to the WSDL Editor by using the
org.eclipse.wst.common.ui.properties.propertyTabs extension point but that
did not work. Adding sections to the WSDL Editor existing tabs via the
org.eclipse.wst.common.ui.properties.propertySections extension point and
that did not work either.
So, it seams that I can only add sections programatically to already
declared tabs. Is there a reason for this?
Mihnea
FUDForum. Page generated in 0.02900 seconds
