Home » Eclipse Projects » BIRT » Getting Primary Y-Axis to Match Secondary Y-Axis
Getting Primary Y-Axis to Match Secondary Y-Axis [message #1086808] Wed, 14 August 2013 19:02 Go to next message
Adam Brousseau is currently offline Adam BrousseauFriend
Hello all,
I am working with BIRT 3.7.2 and have a query that returns the following fields.
Average Max Quantity, Average Max Weight, Max Quantity, Max Weight, and Date
The user is able to select from either quantity or weight and I have a chart with two y-axis to display the average as a bar and the maximum as a line. The reason for this is to allow potential outlyers be identified by the user. I was looking for some help to script setting both y-axis values to the same values. For example if the secondary y-axis goes from 0 to 100 then I want that to reflect on the primary y-axis as well. This way I am not displaying two y-axis with labels. As I will not know what the values are ahead of time scripting is my only option. Below is some scripting that I have found that doesn't work, though I believe this is a similar attempt to what I am working towards. Any help would be most appreciative.
Adam Brousseau
importPackage( Packages.org.eclipse.birt.chart.model.data.impl );
var cht = reportContext.getDesignHandle().findElement("Chart1");
var chart = cht.getReportItem().getProperty("chart.instance");
xAxis = chart.getBaseAxes()[0];
yAxis1 = chart.getOrthogonalAxes( xAxis, true)[0];
yAxis2 = chart.getOrthogonalAxes( xAxis, true)[1];
yscale1 = yAxis1.getScale();
yscale2 = yAxis2.getScale();
yscale2_min = yscale2.getMin();
yscale2_max = yscale2.getMax();
yscale1.setMin(yscale2_min);
yscale1.setMax(yscale2_max);
yscale2 = yscale1;
yAxis2.setScale(yscale1);
Re: Getting Primary Y-Axis to Match Secondary Y-Axis [message #1087515 is a reply to message #1086808] Thu, 15 August 2013 19:21 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Linking this with the same post on BIRT Exchange:
Michael
Developer Evangelist, Silanis
Previous Topic:Multi-Series Gantt Chart Task Labels Not Showing
Next Topic:How to pass dataSetRow[] values in a Crosstab Within a Table
Current Time: Wed Feb 26 17:44:26 GMT 2020
Powered by FUDForum. Page generated in 0.02814 seconds
