Home » Language IDEs » ServerTools (WTP) » wtp-I200602240008 crashes in web service generation
wtp-I200602240008 crashes in web service generation [message #161896] Fri, 24 February 2006 08:02
wtp-I200602240008 crashes when generating a bottom up seb service,
see the stack trace below.
My platform: Eclipse 3.2M5, Java SE 6.0beta
The stack trace:
IWAB0398E Error in generating WSDL from Java:
java.lang.ExceptionInInitializerError
at
org.apache.axis.tools.ant.wsdl.Java2WsdlAntTask.execute(Java 2WsdlAntTask.java:172)
at
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.executeAntTask(Java2WSDLCommand.java:163)
at
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.execute(Java2WSDLCommand.java:87)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:387)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:327)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:226)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$5.run(SimpleCommandEngineManager.java:247)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:360)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:305)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 833)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:217)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:79)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:125)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:119)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:737)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:645)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3287)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2907)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:811 )
at org.eclipse.jface.window.Window.open(Window.java:789)
at
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:126)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at
at
at java.lang.reflect.Method.invoke(Method.java:589)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: Class
org.apache.commons.logging.impl.Log4JLogger does not implement Log
at
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:532)
at
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:272)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :414)
at
org.apache.axis.components.logger.LogFactory.getLog(LogFacto ry.java:37)
at org.apache.axis.wsdl.fromJava.Emitter.<clinit>(Emitter.java:101)
... 51 more
at
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:416)
at
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:525)
... 55 more
Caused by: org.apache.commons.logging.LogConfigurationException: Class
at
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:412)
... 56 more
Previous Topic:WTP refactoring information
Next Topic:included JSP shows error - can export to WAR
Current Time: Sat Apr 19 11:51:24 EDT 2025
Powered by FUDForum. Page generated in 0.07317 seconds
