Home » Modeling » OCL » Adding new operation in OCL standard library
Adding new operation in OCL standard library [message #1085865] Tue, 13 August 2013 13:30 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
i want to add an operation in standard ocl library. The signature of operation is like
real operation(real, real)
I am uncertain about categorizing this operation. This is neither a collection operation nor operation for numeric types(x.floor(), x.abs(), etc)
i want to use it like
let x : Real = operation(20, 2)
Can you please guide me under which category i should define this operation? Should i define it under OclAny category?
[Updated on: Tue, 13 August 2013 13:39]
Report message to a moderator
Re: Adding new operation in OCL standard library [message #1085884 is a reply to message #1085865] Tue, 13 August 2013 13:49 Go to previous messageGo to next message
I don't know what a category is.
See my response on "Re: enabling OCL to parse user definded functions"
Ed Willink
> operation is like
> I am uncertain about categorizing this operation. This is nor a
> collection operation neither operation for numeric types(x.floor(),
> x.abs(), etc)
> Regards,
Re: Adding new operation in OCL standard library [message #1086511 is a reply to message #1085884] Wed, 14 August 2013 09:36 Go to previous messageGo to next message
I meant context by category
like
real.abs() has Real as context and collection opertions have Collection context.
I do not want to have context like real.abs()
i want to use following OCL "let x : Real = myoperation(100,2) in x"
where i have defined operation in standard library under
type OclAny : AnyType {
annotation 'http://www.omg.org/ocl'(ClassGroup='OCL');
operation myoperation(a: Real, b: Real) : Real => 'path to implementation class';
but i am getting following exceptions...
org.eclipse.ocl.examples.pivot.SemanticException: Errors in 'let x : Real = myoperation(100,2) in x'
1: Unresolved Operation '::myoperation(UnlimitedNatural, UnlimitedNatural)'
at org.eclipse.ocl.examples.pivot.utilities.PivotUtil.checkResourceErrors(PivotUtil.java:171)
at org.eclipse.ocl.examples.pivot.context.AbstractParserContext.parse(AbstractParserContext.java:120)
at org.eclipse.ocl.examples.pivot.helper.OCLHelperImpl.createQuery(OCLHelperImpl.java:124)
at oclextplugin.ext.OCLStdLibTest.<init>(OCLStdLibTest.java:85)
at oclextplugin.View.createPartControl(View.java:71)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:174)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
Do you have any idea why is that?
[Updated on: Wed, 14 August 2013 09:38]
Re: Adding new operation in OCL standard library [message #1086521 is a reply to message #1086511] Wed, 14 August 2013 09:45 Go to previous messageGo to next message
HI
Please attach a zipped project so that I can see what you're doing.
Ed Willink
> like
> Collection context.
> where i have defined operation in standard library under type OclAny :
> AnyType {
> operation myoperation(mean: Real, sd: Real) : Real => 'path to
> UnlimitedNatural)'
> at
> at
> at
> at
> at
> at
Re: Adding new operation in OCL standard library [message #1086568 is a reply to message #1086521] Wed, 14 August 2013 11:16 Go to previous messageGo to next message
I have attached org.eclipse.ocl.examples.library plugin as zip and it contains OCL standard library. I have added following into it
AnyType {
operation myoperation(a: Real, b: Real) : Real => 'org.eclipse.ocl.examples.library.oclany.MyOperation';
and i am using following code to test newly added operation in OCL standard library.
org.eclipse.ocl.examples.pivot.OCL ocl = org.eclipse.ocl.examples.pivot.OCL.newInstance();
org.eclipse.ocl.examples.pivot.helper.OCLHelper helper = ocl.createOCLHelper();
ExpressionInOCL exp = helper.createQuery("let x : Real = myoperation(100,2) in x");
Query q = ocl.createQuery(exp);
System.out.println("result = " + q.evaluate());
Re: Adding new operation in OCL standard library [message #1086756 is a reply to message #1086568] Wed, 14 August 2013 17:15 Go to previous messageGo to next message
You are not adding to the OCL Standard Library, you are replacing it.
You therefore have to make sure that you use your artefacts rather than
those avialbale from the installed version. You haven't chnaged the
nsURI either.
You should extend the library not replace it. If you replace it use a
new nsURI.
Ed Willink
> AnyType {
> Regards,
Re: Adding new operation in OCL standard library [message #1087161 is a reply to message #1086756] Thu, 15 August 2013 08:07 Go to previous messageGo to next message
I have added some other operation (some under collection context and some for primitive types like integer and real) and they are working fine. This is the first operation i tried to add under OCLAny context.
I have tried to change uri from http://www.eclipse.org/ocl/3.1.0/OCL.oclstdlib to http://www.eclipse.org/ocl/3.1.1/OCL.oclstdlib
After doing that when i try to run GenerateOCLstdlibModel.mwe2 then i get the following exception
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri 'C:\Users\KhurramS\git\kepler\org.eclipse.ocl\examples'
2809 [main] INFO ld.utilities.OCLstdlibCodeGenerator - Loading OCL library 'platform:/resource/org.eclipse.ocl.examples.library/model/OCL-2.4.oclstdlib
17443 [main] INFO ld.utilities.OCLstdlibCodeGenerator - Generating to ' C:\Users\KhurramS\git\kepler\org.eclipse.ocl\examples\org.eclipse.ocl.examples.pivot\emf-gen\org\eclipse\ocl\examples\pivot\model'
20205 [main] INFO ild.utilities.Model2tablesGenerator - Loading Gen Model 'platform:/resource/org.eclipse.ocl.examples.library/model/oclstdlib.genmodel
22125 [main] INFO ild.utilities.Model2tablesGenerator - Generating to ' C:\Users\KhurramS\git\kepler\org.eclipse.ocl\examples\org.eclipse.ocl.examples.library\emf-gen'
23155 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow GenerateOCLstdlibModel: Problems running Model2tablesGenerator
java.lang.RuntimeException: Problems running workflow GenerateOCLstdlibModel: Problems running Model2tablesGenerator
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: java.lang.RuntimeException: Problems running Model2tablesGenerator
at org.eclipse.ocl.examples.build.utilities.Model2tablesGenerator.invokeInternal(Model2tablesGenerator.java:112)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
... 4 more
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.getType(MetaModelManager.java:2324)
at org.eclipse.ocl.examples.codegen.oclinecore.OCLinEcoreTablesUtils.getAllSuperClasses(OCLinEcoreTablesUtils.java:648)
at org.eclipse.ocl.examples.codegen.oclinecore.OCLinEcoreTablesUtils.getAllSupertypesSortedByName(OCLinEcoreTablesUtils.java:633)
at org.eclipse.ocl.examples.codegen.oclinecore.OCLinEcoreTables.declareFragments(OCLinEcoreTables.java:216)
at org.eclipse.ocl.examples.codegen.oclinecore.OCLinEcoreTables.generateTablesClass(OCLinEcoreTables.java:902)
at org.eclipse.ocl.examples.build.utilities.Model2tablesGenerator.invokeInternal(Model2tablesGenerator.java:105)
... 10 more
I have also tried to extend OCL standard library, in that case GenerateOCLstdlibModel.mwe2 runs fine but it generate lot of problematic code in emf-gen folder of pivot plugin
Re: Adding new operation in OCL standard library [message #1087167 is a reply to message #1086756] Thu, 15 August 2013 08:17 Go to previous messageGo to next message
I have also tried to extend like
import 'OCL-2.4.oclstdlib';
library ocl : ocl = 'http://www.eclipse.org/ocl/3.1.0/OCL.oclstdlib'{
type Integer : PrimitiveType conformsTo Real {
operation test() : Integer =>'org.eclipse.ocl.examples.library.numeric.TestNumericOperation';
and i changed the GenerateOCLstdlibModel.mwe2 to point to new ocl standard library file.
import org.eclipse.ocl.examples.build.utilities.*
import org.eclipse.emf.mwe.utils.*
import org.eclipse.emf.ecore.resource.impl.*
var sourceName = "org.eclipse.ocl.examples.library"
var targetName = "org.eclipse.ocl.examples.pivot"
* Generate the OCLstdlib Model, by converting oclstdlib.oclstdlib to OCLstdlib.java.
Workflow {
bean = ResourceSetImpl : resourceSet {}
bean = StandaloneSetup { resourceSet = resourceSet
platformUri = ".."
component = OCLstdlibCodeGenerator { resourceSet = resourceSet
uri = "http://www.eclipse.org/ocl/3.1.0/OCL.oclstdlib"
//libraryFile = "/${sourceName}/model/OCL-2.4.oclstdlib"
libraryFile = "/${sourceName}/model/extendedOCL.oclstdlib"
javaFolder = "/${targetName}/emf-gen"
javaPackageName = "${targetName}.model"
javaClassName = "OCLstdlib"
component = Model2tablesGenerator { resourceSet = resourceSet
genModelFile = "/${sourceName}/model/oclstdlib.genmodel"
genOCLstdlib = true
it gives me following error
7257 [main] ERROR .examples.build.acceleo.NameQueries - getPrefixedSymbolName for 'orphans'and null
process completes with out any exception but OCLstdlib.java file does not contains methods like installCollectionTypes, installMetaclasses etc and obviously this means compilation errors.
can you please identify the problem here.
thanks!
Re: Adding new operation in OCL standard library [message #1087182 is a reply to message #1087167] Thu, 15 August 2013 08:49 Go to previous messageGo to next message
You are using 'examples' code that has not been released and lacks
tutorials and in many cases going beyond what is supported.
I am afraid that at present I have very limited time and so can only
answer simple queries. Yours are not simple, so you'll have to help
yourself.
Sorry.
Ed Willink
> to OCLstdlib.java.
> Workflow {
> platformUri = ".."
> genOCLstdlib = true
> thanks!
Re: Adding new operation in OCL standard library [message #1087199 is a reply to message #1087182] Thu, 15 August 2013 09:16 Go to previous messageGo to next message
Yes i can understand.
i would like to ask one simple question then
i have defined myoperation under OCLAny
"let x : Real = myoperation(100,2) in x" does not work and gives exception
but "let x : Real = 10 in x.myoperation(100,2)" works perfecly
and also "let x : Real = OclAny.myoperation(100,2) in x" works perfectly
do you have any clue why first ocl statement myoperation is not recognized?
thanks for your help!
regards,
[Updated on: Thu, 15 August 2013 09:29]
Re: Adding new operation in OCL standard library [message #1087276 is a reply to message #1087199] Thu, 15 August 2013 11:55 Go to previous message
Because from what I have seen you have a very tangled mixture of
standard and extended functionality, it is impossible to give a quick
answer as to whether the problem is due to the tangle, a bug in your
code or a bug in the underlying code.
Ed Willink
> let x : Real = myoperation(100,2) in x does not work and gives exception
> but let x : Real = 10 in x.myoperation(100,2) works perfecly
> recognized?
> regards,
Previous Topic:Error messages of the Audit Rule not shown!!!!
Next Topic:[Announce] Eclipse OCL 4.1.1 RC1 and OCL 4.2.0 M1 are available.
Current Time: Sat Sep 21 03:29:32 GMT 2024
Powered by FUDForum. Page generated in 0.04267 seconds
