Home » Eclipse Projects » BIRT » SQL on DetailRow or Table in Table
SQL on DetailRow or Table in Table [message #1085852] Tue, 13 August 2013 13:11 Go to next message
Marina Orth is currently offline Marina OrthFriend
Member
I have two tables. Table two is inside table one. Table two has one parameter param_1. Over "Binding" and "Data Set Parameter Binding" i bounded param_1 to row["Number"] from table one. So i expected the sql statement executed for every number in table one. But i've got a error message: can not load the report query...
What did i do wrong? What can i try?
[Updated on: Tue, 13 August 2013 14:00]
Report message to a moderator
Re: SQL on DetailRow or Table in Table [message #1085920 is a reply to message #1085852] Tue, 13 August 2013 14:42 Go to previous message
Member
After searching in www i found http://wiki.eclipse.org/MasterDetailOneReport_%28BIRT%29#Example_Files
it helped. All is fine
Previous Topic:How to get hyperlinks in BIRT report viewer
Next Topic:user & password parameters to connect
Current Time: Tue Jan 28 07:17:33 GMT 2020
Powered by FUDForum. Page generated in 0.01619 seconds
