Re: Enable offline working on Papyrus Models [message #1089395 is a reply to message #1085840] |
Sun, 18 August 2013 17:26 |
I assume you are asking about off-line access to Papyrus models stored
in a CDO repository. If so, this is not in the scope of the Papyrus
integration with CDO: Papyrus just connects to a repository that you
identify, whether that be a local (off-line) clone or a remote
repository. The cloning and synchronization of repositories is managed
separately by whatever means the CDO project or your own code provides.
You may find Eike's off-line repository example a useful starting point:
http://thegordian.blogspot.ca/2012/11/use-online-data-offline.html
HTH,
Christian
On 2013-08-13 12:53:11 +0000, SA Poliana said:
> I would like to know how to enable offline working on Papyrus models
> located in a remote machine.
> thanks :)
FUDForum. Page generated in 0.02819 seconds
