Loving the Team Concept but... problem with AD users [message #1085595] |
Tue, 13 August 2013 05:26 |
Andreas Magnusson Messages: 7 Registered: June 2010 |
Junior Member |
Just tried our the Team Concept and it look great. However, it behaves "not so good" in combination with the Active Directory plugin.
The reason is that from AD's perspective, usernames are case agnostic, which means that I can logon as AMagnusson, amagnusson or some other combination, all which are correct.
The user mapping in Hudson seems to use the case that I as a user entered, which only might be the one used by the admin when added to the Team.
I recognize this problem from our own product, and there we made sure that the user handling always looks up the user via the mechanism (in this case AD) which (again at least in our API) always can return a unique name for the user. And always the same (of course).
Or, perhaps the usernames shouldn't be case-sensitive? That is up to you.
In the mean time I will test LDAP configuration to see if that one can handle usernames with different casing.
/Andreas
FUDForum. Page generated in 0.03701 seconds
