Home » Eclipse Projects » NatTable » activateCell() method doesn't get called(The activateCell() method is supposed to be called by itself when a cell is selected, but it doesn't get called.)
activateCell() method doesn't get called [message #1084930] Mon, 12 August 2013 08:22 Go to next message
Ali Malik is currently offline Ali MalikFriend
I am using a custom editor for the NatTable.
I need to show a combo box editor in selective cells of a column, not all of them.
For this, I decided to use a custom editor, which implements the ICellEditor Interface.
I overrode the public Control activateCell(Composite , Object , Character EditModeEnum , ICellEditHandler , ILayerCell ,IConfigRegistry )
Though, I haven't yet implemented the functionality, but the method should be called when i select the cell.
I call it like this:
configRegistry.registerConfigAttribute(
EditConfigAttributes.CELL_EDITOR, new CustomEditor(),
DisplayMode.NORMAL, QueryTreeTable.COLUMN_TWO_LABEL);
Any suggestions on what am I doing wrong?
Re: activateCell() method doesn't get called [message #1085114 is a reply to message #1084930] Mon, 12 August 2013 13:22 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
What do you mean by that?
I think you need to register against DisplayMode.EDIT
Re: activateCell() method doesn't get called [message #1085659 is a reply to message #1085114] Tue, 13 August 2013 07:28 Go to previous messageGo to next message
I meant some cells should show TextPainter, and some should show ComboBoxPainter.
That EDIT or NORMAL weren't a problem.
I got it solved by reading another thread.
The problem was i had to bind the Custom Editor with the UiBindingRegistry. I did it and it is working fine, now, with the following code.
            CustomEditor editor = new CustomEditor( bodyDataProvider, configRegistry );
            UiBindingRegistry uiBindingRegistry = natTable.getUiBindingRegistry();
            uiBindingRegistry.registerFirstSingleClickBinding(
            	    new BodyCellEditorMouseEventMatcher(editor.getClass()),
            	    new MouseEditAction());
                    EditConfigAttributes.CELL_EDITOR, editor,
Thank you for your help, Dirk. Do you know any reason why do we have to bind it like this? I mean why doens't it bind it through some internal mechanism?
Ali Ahmad Malik
Re: activateCell() method doesn't get called [message #1085692 is a reply to message #1085659] Tue, 13 August 2013 08:31 Go to previous message
Which version are you using? Using NatTable 1.0 should bind the editor automatically. There the BodyCellEditorMouseEventMatcher is deprecated.
Previous Topic:ColumnGroupHeaderLayer expand/collapse and Selection, ColumnResize, etc.
Next Topic:Multiple Selection is not enforced after setting flag in the selection model.
Current Time: Fri Feb 21 14:02:36 GMT 2020
Powered by FUDForum. Page generated in 0.02219 seconds
