Home » Archived » Eclipse Process Manager (Stardust) » How to define mapping for JAXWS web service call
How to define mapping for JAXWS web service call [message #1084906] Mon, 12 August 2013 07:50 Go to next message
Ravinderjit Singh is currently offline Ravinderjit SinghFriend
I am trying to call a JAX-WS websevice. Following Stardust documents System Integration/Synchronous Web Services.
1. Added WS Application, able to load all the required details.
2. Created in and out XML Data using WSDL (XSD Envelope) option.
When starting the process getting below error.
org.eclipse.stardust.common.error.PublicException: Invalid XML access point.: : Content is not allowed in prolog
I think something is wrong with my mappings and Access points.
Please let me know what I can provide you to look into it.
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1085571 is a reply to message #1084906] Tue, 13 August 2013 04:33 Go to previous messageGo to next message
Can anyone please help me to understand how to do the mappings.
I am unable to find any sample and documentation doesn't say much about it.
Ravinderjit
[Updated on: Tue, 13 August 2013 04:34]
Report message to a moderator
Re: How to define mapping for JAXWS web service call [message #1085680 is a reply to message #1085571] Tue, 13 August 2013 08:09 Go to previous messageGo to next message
Robert Emsbach is currently offline Robert EmsbachFriend
Ravindejit,
1. Did you import the request and response types of the operation from your WSDL as strucutured data types? (import type from URL, can aslo be on the local file system)
2. Then you create two structured data using those two types.
3. Map the request structured data into the activity that your WS application type is connected to, to the request access point.
4. Map the response (access point) from the activity that your WS application type is connected to to the response structured data.
Does this help?
Rob
Re: How to define mapping for JAXWS web service call [message #1085779 is a reply to message #1085680] Tue, 13 August 2013 11:06 Go to previous messageGo to next message
Rob,
1. No I was not doing it this way, Thanks for your instructions.
I think I am making progress here.
Earlier it used to complain about 'Invalid Access point', but now my first activity got completed successfully.
Still getting error for activity which call WSDL.
Here is the stacktrace.
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'InputValue', oid: 7 (process instance = 5): Application-->Completed.
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - Remove from worklists: Activity instance 'InputValue', oid: 7 (process instance = 5)
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'CallWSDL', oid: 8 (process instance = 5): Created-->Created.
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'CallWSDL', oid: 8 (process instance = 5): Created-->Application.
16:27:47 WARN [ttp-8080-8] ApplicationException -
org.xml.sax.SAXParseException; systemId: file:///C:/eclipse-kepler/; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
at org.apache.xerces.impl.XMLScanner.reportFatalError(Unknown Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl$PrologDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.eclipse.stardust.engine.core.runtime.utils.XmlUtils.parseSource(XmlUtils.java:816)
at org.eclipse.stardust.engine.core.runtime.utils.XmlUtils.parseString(XmlUtils.java:756)
at org.eclipse.stardust.engine.core.runtime.utils.XmlUtils.parseString(XmlUtils.java:731)
at org.eclipse.stardust.engine.extensions.jaxws.app.WebserviceApplicationInstance.setInAccessPointValue(WebserviceApplicationInstance.java:643)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.processInDataMappings(ActivityInstanceBean.java:1569)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1405)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1223)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invoke(ActivityInstanceBean.java:1020)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.doStartActivity(ActivityInstanceBean.java:1010)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.start(ActivityInstanceBean.java:971)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runCurrentActivity(ActivityThread.java:748)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.run(ActivityThread.java:330)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.schedule(ActivityThread.java:118)
at org.eclipse.stardust.engine.core.runtime.audittrail.management.ActivityInstanceUtils.complete(ActivityInstanceUtils.java:363)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:905)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:790)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.GuardingInterceptor.invoke(GuardingInterceptor.java:55)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.performCall(AbstractLoginInterceptor.java:171)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.invoke(AbstractLoginInterceptor.java:109)
at org.eclipse.stardust.engine.api.spring.SpringBeanLoginInterceptor.invoke(SpringBeanLoginInterceptor.java:67)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:143)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:48)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:87)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:341)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:81)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:55)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:66)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:130)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:51)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at com.sun.proxy.$Proxy123.complete(Unknown Source)
at org.eclipse.stardust.engine.api.spring.WorkflowServiceBean.complete(WorkflowServiceBean.java:68)
at org.eclipse.stardust.engine.api.spring.SpringServiceFactory$SpringServiceInvocationHandler.invoke(SpringServiceFactory.java:178)
at org.eclipse.stardust.ui.web.processportal.common.PPUtils.complete(PPUtils.java:438)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivityContinue(ActivityDetailsBean.java:1478)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.access$1000(ActivityDetailsBean.java:138)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean$7.handleEvent(ActivityDetailsBean.java:1455)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMappingContinue(ActivityDetailsBean.java:1694)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMapping(ActivityDetailsBean.java:1675)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1440)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.processActivityInstance(ActivityDetailsBean.java:1552)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.showMappedDocumentWarningAndProcessActivity(ActivityDetailsBean.java:1606)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeAction(ActivityDetailsBean.java:1424)
at com.sun.el.parser.AstValue.invoke(AstValue.java:130)
at com.sun.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:274)
at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68)
at com.sun.facelets.el.LegacyMethodBinding.invoke(LegacyMethodBinding.java:69)
at javax.faces.component.UICommand.broadcast(UICommand.java:89)
at org.eclipse.stardust.ui.web.common.app.tags.TabScopedComponent.broadcast(TabScopedComponent.java:148)
at javax.faces.component.UIViewRoot._broadcastForPhase(UIViewRoot.java:97)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:171)
at org.apache.myfaces.lifecycle.InvokeApplicationExecutor.execute(InvokeApplicationExecutor.java:32)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:50)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:169)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:110)
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:65)
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51)
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:62)
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55)
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107)
at com.icesoft.faces.webapp.http.servlet.BlockExpiredSessionRequests.service(BlockExpiredSessionRequests.java:53)
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:723)
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:71)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
16:27:47 WARN [ttp-8080-8] AuditTrailLogger - org.eclipse.stardust.common.error.PublicException: : Content is not allowed in prolog. (User: motu (Realm: carnot) (Of the Universe, Master))
16:27:47 INFO [ttp-8080-8] ProcessInstanceBean - State change for Process instance = 5 (Process Definition: Process Definition 1): Active-->Interrupted.
16:27:47 INFO [ttp-8080-8] AuditTrailLogger - Process instance interrupted. (User: motu (Realm: carnot) (Of the Universe, Master))
16:27:47 INFO [ttp-8080-8] ActivityInstanceBean - State change for Activity instance 'CallWSDL', oid: 8 (process instance = 5): Application-->Interrupted.
16:27:48 WARN [ttp-8080-8] AuditTrailLogger - Activity thread interrupted at 'Activity: Call WSDL', reason: org.eclipse.stardust.common.error.PublicException: : Content is not allowed in prolog. (User: motu (Realm: carnot) (Of the Universe, Master))
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1085793 is a reply to message #1085779] Tue, 13 August 2013 11:33 Go to previous messageGo to next message
Rob,
This is the Application section getting generated in .xpdl file.
Do you see something wrong here ?
<Applications>
      <Application Id="HelloWS" Name="HelloWS">
         <ExternalReference location="[url]http://localhost:9090/ws/hello?wsdl[/url]" xref="getHelloWorldAsString" namespace="HelloWorldImplPort"/>
         <ExtendedAttributes>
            <ExtendedAttribute Name="CarnotExt">
               <carnot:Application Oid="53" Type="webservice">
                  <carnot:ApplicationContexts/>
                  <carnot:AccessPoints>
                     <carnot:AccessPoint Oid="54" Id="carnot:engine:endpointAddress" Name="Endpoint Address" Direction="IN" Type="serializable">
                        <carnot:Attributes>
                           <carnot:Attribute Name="carnot:engine:className" Value="java.lang.String"/>
                           <carnot:Attribute Name="carnot:engine:browsable" Value="true" Type="boolean"/>
                        </carnot:Attributes>
                     </carnot:AccessPoint>
                     <carnot:AccessPoint Oid="55" Id="parameters" Name="parameters" Direction="IN" Type="plainXML">
                        <carnot:Attributes>
                     <carnot:AccessPoint Oid="56" Id="parameters" Name="parameters" Direction="OUT" Type="plainXML"/>
                  </carnot:AccessPoints>
                  <carnot:Attributes>
                     <carnot:Attribute Name="carnot:engine:visibility" Value="Public"/>
                     <carnot:Attribute Name="synchronous:retry:enable" Value="false" Type="boolean"/>
                     <carnot:Attribute Name="carnot:engine:wsdlUrl" Value="[url]http://localhost:9090/ws/hello?wsdl[/url]"/>
                     <carnot:Attribute Name="carnot:engine:wsServiceName" Value="[url]{http://jaxws.ws.example.com/}HelloWorldImplService[/url]"/>
                     <carnot:Attribute Name="carnot:engine:wsPortName" Value="HelloWorldImplPort"/>
                     <carnot:Attribute Name="carnot:engine:wsOperationName" Value="getHelloWorldAsString"/>
                     <carnot:Attribute Name="carnot:engine:wsSoapProtocol" Value="SOAP 1.1 Protocol"/>
                     <carnot:Attribute Name="carnot:engine:wsInputOrder" Value="parameters"/>
                     <carnot:Attribute Name="carnot:engine:wsOutputOrder" Value="parameters"/>
               </carnot:Application>
            </ExtendedAttribute>
         </ExtendedAttributes>
      </Application>
   </Applications>
Ravinderjit
[Updated on: Wed, 14 August 2013 11:23]
Re: How to define mapping for JAXWS web service call [message #1085818 is a reply to message #1085793] Tue, 13 August 2013 12:20 Go to previous messageGo to next message
Rob,
I manage to make it work.
I used Generate classes option for mapping.
Thanks for your help.
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1085914 is a reply to message #1085818] Tue, 13 August 2013 14:36 Go to previous messageGo to next message
Rob,
Can you please help me to understand how can I do the mapping without generating the classes for operation in/out parameters?
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1086333 is a reply to message #1085914] Wed, 14 August 2013 05:07 Go to previous messageGo to next message
Ravinderjit,
it usually work without generating classes in the way I described above. Import the required request and response types as structured data types and use data based on those types as in and out data.
Is that what you did when you got the
This seems to be a very low level error that does not involve Stardust code. The xml processor has an issue parsing the xml.
What could be the reason for that? Can you ensure the XML is 100% valid? What is the first character in the file? (Would it be possible to share that file?)
Does the error change if you copy the type into the model when importing it instead of importing it be reference?
Rob
Re: How to define mapping for JAXWS web service call [message #1086536 is a reply to message #1086333] Wed, 14 August 2013 10:11 Go to previous messageGo to next message
Rob,
Now I am not getting this error "org.xml.sax.SAXParseException; systemId: file:///C:/eclipse-kepler/; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.". Even if I use XML Template instead of generated classes.
But now my data is not getting mapped for WSDL Call, WSDL is getting called with null value.
This is what I get in XPDL file for application.
   <Applications>
      <Application Id="JAXWSHelloWS" Name="JAXWSHelloWS">
         <ExternalReference location="http://localhost:9090/ws/hello?wsdl" xref="getHelloWorldAsString" namespace="HelloWorldImplPort"/>
               <carnot:Application Oid="55" Type="webservice">
                     <carnot:AccessPoint Oid="56" Id="carnot:engine:endpointAddress" Name="Endpoint Address" Direction="IN" Type="serializable">
                        <carnot:Attributes>
                     <carnot:AccessPoint Oid="57" Id="parameters" Name="parameters" Direction="IN" Type="plainXML">
                        <carnot:Attributes>
                     <carnot:AccessPoint Oid="58" Id="parameters_struct" Name="parameters_struct (getHelloWorldAsString)" Direction="IN" Type="struct">
                        <carnot:Attributes>
                           <carnot:Attribute Name="carnot:engine:dataType" Value="getHelloWorldAsString"/>
                           <carnot:Attribute Name="carnot:engine:transformation" Value="DOM"/>
                           <carnot:Attribute Name="carnot:engine:path:separator" Value="/"/>
                           <carnot:Attribute Name="carnot:engine:data:bidirectional" Value="true" Type="boolean"/>
                     <carnot:AccessPoint Oid="59" Id="parameters" Name="parameters" Direction="OUT" Type="plainXML"/>
                     <carnot:AccessPoint Oid="60" Id="parameters_struct" Name="parameters_struct (getHelloWorldAsStringResponse)" Direction="OUT" Type="struct">
                        <carnot:Attributes>
                           <carnot:Attribute Name="carnot:engine:dataType" Value="getHelloWorldAsStringResponse"/>
                  <carnot:Attributes>
                     <carnot:Attribute Name="carnot:engine:wsdlUrl" Value="http://localhost:9090/ws/hello?wsdl"/>
                     <carnot:Attribute Name="carnot:engine:wsServiceName" Value="{http://jaxws.ws.example.com/}HelloWorldImplService"/>
      </Application>
   </Applications>
These are the data fields
      <DataField Id="InData" Name="InData" IsArray="FALSE">
         <DataType>
            <DeclaredType Id="getHelloWorldAsString"/>
         </DataType>
               <carnot:DataField Oid="53" Type="struct">
                  <carnot:Attributes>
                     <carnot:Attribute Name="authorization:data.readDataValues" Value="__carnot_internal_all_permissions__"/>
               </carnot:DataField>
      </DataField>
      <DataField Id="OutData" Name="OutData" IsArray="FALSE">
         <DataType>
            <DeclaredType Id="getHelloWorldAsStringResponse"/>
         </DataType>
               <carnot:DataField Oid="54" Type="struct">
                  <carnot:Attributes>
               </carnot:DataField>
      </DataField>
   </DataFields>
Dataflow for first activity where user will enter the value. I don't see any AccessPointRef here.
<carnot:DataFlows>
                           <carnot:DataFlow Oid="79" Id="InData" Name="InData" Direction="OUT" Context="default">
                              <carnot:DataRef Id="InData" Expression="arg0"/>
                              <carnot:AccessPointRef/>
                           </carnot:DataFlow>
                        </carnot:DataFlows>
Dataflow for WSDL Call activity
<carnot:DataFlows>
                           <carnot:DataFlow Oid="81" Id="InData" Name="InData" Direction="IN" Context="application">
                              <carnot:DataRef Id="InData"/>
                              <carnot:AccessPointRef Id="parameters_struct"/>
                           </carnot:DataFlow>
                           <carnot:DataFlow Oid="83" Id="OutData" Name="OutData" Direction="OUT" Context="application">
                              <carnot:DataRef Id="OutData"/>
                           </carnot:DataFlow>
                        </carnot:DataFlows>
I can share my project with you, but how to do upload files here ?
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1087036 is a reply to message #1086536] Thu, 15 August 2013 03:42 Go to previous messageGo to next message
Ravinderjit,
please try to refresh all the settings and see if there are any validation warning on your data mappings or your application activity.
I think we cannot upload files to the Eclipse forum. Can you share it via dropbox or so? Or you can email it to ippDOTenablingATsunagrdDOTcom.
Rob
Re: How to define mapping for JAXWS web service call [message #1087069 is a reply to message #1087036] Thu, 15 August 2013 04:57 Go to previous messageGo to next message
Rob,
I am not getting any warming for data mappings.
You can get my project from here https://dl.dropboxusercontent.com/u/42370205/WSDLCallTest.zip
This is the my local JAXWS service https://dl.dropboxusercontent.com/u/42370205/WebServices.zip
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1089889 is a reply to message #1087069] Mon, 19 August 2013 11:48 Go to previous messageGo to next message
Rob,
Did you get chance to look at my project?
Ravinderjit
Re: How to define mapping for JAXWS web service call [message #1091869 is a reply to message #1089889] Thu, 22 August 2013 04:05 Go to previous message
Ravinderjit,
I downloaded the projects, but did not deploy both of them. To reduce possible error source and to be quicker I
- used hello.wsdl and mocked the service with SOAP UI under the same url (http://localhost:9090/ws/hello?WSDL)
- created a plain vanilla RAD project
- added the hello.xsd from your project to the project's src folder so the modeler could resolve the references to the structured types
- opened your process model, made sure the WSDL loaded without errors from the unchanged URL
- double checked data mappings on the activiy (made no changes)
- started my server and deployed the model
- logged in an ran the process
- stepped through the process.
The request reached SOAP UI successfully and the response was correctly processed by the engine and displayed in the second manual activity.
Could you try if the same works for you?
If yes, in the next step can you replace the service mock with the actual service you generated (no other changes) and see if it still works?
Rob
[Updated on: Thu, 22 August 2013 04:24]
Previous Topic:Install trouble
Next Topic:Stardust 1.0 with maven
Current Time: Tue Apr 16 17:08:16 GMT 2024
Powered by FUDForum. Page generated in 0.10436 seconds
