Home » Language IDEs » C / C++ IDE (CDT) » Use Build Output Parser (BOP) to find include path(What are the settings needed for this to work?)
Use Build Output Parser (BOP) to find include path [message #1082383] Thu, 08 August 2013 09:53 Go to next message
I'm trying to setup CDT so that I can work on a little kernel driver tutorial I've found.
CDT offers the "Build Output Parser (BOP)" options which is supposed to extract the include paths from the build output.
What options do I have to set for this to work with gnu make and gcc? Unfortunately I haven't found anything on the internet about this topic.
I'm currently using CDT 8.2.0.
Martin
[Updated on: Thu, 08 August 2013 11:45] by Moderator
Re: Use Build Output Parser (BOP) to find include path [message #1082495 is a reply to message #1082383] Thu, 08 August 2013 12:46 Go to previous messageGo to next message
Try http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Fconcepts%2Fcdt_c_scanner_discovery.htm
Andrew
Re: Use Build Output Parser (BOP) to find include path [message #1082901 is a reply to message #1082495] Fri, 09 August 2013 03:15 Go to previous messageGo to next message
unfortunately I don't see any hints on how to configure CDT and the make and GCC command line parameters. I have uploaded the current project and build output with a screenshot of my current Build Output Parser settings.
Re: Use Build Output Parser (BOP) to find include path [message #1083107 is a reply to message #1082901] Fri, 09 August 2013 09:35 Go to previous message
It considers lines that start with "gcc" and end with C file being compiled. Your compile command is embedded into shell script. If you manage to print the compile command in build output on separate line it should parse it. Also, the C file has to be a part of the project.
Andrew
Previous Topic:Add default run-configuration on project create
Next Topic:ASTRewrite and Preprocessor Macros
Current Time: Mon Jun 16 15:33:31 EDT 2025
Powered by FUDForum. Page generated in 0.04168 seconds
