Creating a Web Service - IWAB0014E Unexpected exception occured [message #160538] |
Mon, 13 February 2006 09:48  |
I am new to Eclipse WST. I have Windows XP / J2SE 1.5.0_06-b05 /
Eclipse SDK 3.1.2 build id M20060118-1600/ WST 1.0. When I tried to
create a Web Service project, I get the following error. I dont have a
clue of whats going on. Can any one help?
IWAB0014E Unexpected exception occured.
0
java.lang.ArrayIndexOutOfBoundsException: 0
at
org.eclipse.jst.ws.internal.consumption.ui.wsrt.WebServiceRu ntimeExtensionUtils2.getDefaultServerValueFor(WebServiceRunt imeExtensionUtils2.java:508)
at
org.eclipse.jst.ws.internal.creation.ui.widgets.ServerWizard WidgetDefaultingCommand.execute(ServerWizardWidgetDefaulting Command.java:33)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:386)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:327)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:226)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$5.run(SimpleCommandEngineManager.java:247)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:211)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:78)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:124)
at
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.getStartingPage(DynamicWizard.java:314)
at
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:112)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:99)
at
org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advan ceToNextPageOrFinish(NewWizardSelectionPage.java:71)
at
org.eclipse.ui.internal.dialogs.NewWizardNewPage$2.doubleCli ck(NewWizardNewPage.java:372)
at
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:720)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:718)
at
org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelec t(StructuredViewer.java:950)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1057)
at
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:219)
at
org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:216)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:275)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.03487 seconds
