Home » Eclipse Projects » BIRT » org.eclipse.datatools.connectivity.oda.OdaException(org.eclipse.datatools.connectivity.oda.OdaException)
org.eclipse.datatools.connectivity.oda.OdaException [message #1080805] Tue, 06 August 2013 11:46 Go to next message
Rajan Rath is currently offline Rajan RathFriend
I am getting the error below when I select the XML file and the XSD file. I have verified that the XML is valid against the XSD and the XSD is valid. Any further pointers?
org.eclipse.datatools.connectivity.oda.OdaException: The provided xsd file is invalid.
at org.eclipse.datatools.enablement.oda.xml.util.ui.XSDFileSchemaTreePopulator.loadSchema(SchemaPopulationUtil.java:433)
at org.eclipse.datatools.enablement.oda.xml.util.ui.XSDFileSchemaTreePopulator.getSchemaTree(SchemaPopulationUtil.java:352)
at org.eclipse.datatools.enablement.oda.xml.util.ui.SchemaPopulationUtil.getSchemaTree(SchemaPopulationUtil.java:65)
at org.eclipse.datatools.enablement.oda.xml.ui.wizards.XPathChoosePage.populateXMLTree(XPathChoosePage.java:390)
at org.eclipse.datatools.enablement.oda.xml.ui.wizards.XPathChoosePage.createPageCustomControl(XPathChoosePage.java:109)
at org.eclipse.datatools.connectivity.oda.design.ui.wizards.DataSetWizardPage.createControl(DataSetWizardPage.java:123)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:669)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1083)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1142)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog.java:1139)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.java:1128)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1126)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:820)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.birt.report.designer.ui.actions.NewDataSetAction.createNewDataSet(NewDataSetAction.java:157)
at org.eclipse.birt.report.designer.ui.actions.NewDataSetAction.run(NewDataSetAction.java:142)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: org.eclipse.datatools.connectivity.oda.OdaException [message #1083571 is a reply to message #1080805] Sat, 10 August 2013 05:29 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Can you attach the files or sample files that produce the same issue, if you cannot attach your real data? Thanks!
Michael
Developer Evangelist, Silanis
Previous Topic:Disable LOG
Next Topic:Interactive time charts in eclipse RAP
Current Time: Mon Jan 27 05:19:18 GMT 2020
Powered by FUDForum. Page generated in 0.02078 seconds
