org.eclipse.datatools.connectivity.oda.OdaException [message #1080801] |
Tue, 06 August 2013 11:45 |
Rajan Rath Messages: 2 Registered: August 2013 |
I am getting the error below when I select the XML file and the XSD file. I have verified that the XML is valid against the XSD and the XSD is valid. Any further pointers?
org.eclipse.datatools.connectivity.oda.OdaException: The provided xsd file is invalid.
at org.eclipse.datatools.enablement.oda.xml.util.ui.XSDFileSchemaTreePopulator.loadSchema(SchemaPopulationUtil.java:433)
at org.eclipse.datatools.enablement.oda.xml.util.ui.XSDFileSchemaTreePopulator.getSchemaTree(SchemaPopulationUtil.java:352)
at org.eclipse.datatools.enablement.oda.xml.util.ui.SchemaPopulationUtil.getSchemaTree(SchemaPopulationUtil.java:65)
at org.eclipse.datatools.enablement.oda.xml.ui.wizards.XPathChoosePage.populateXMLTree(XPathChoosePage.java:390)
at org.eclipse.datatools.enablement.oda.xml.ui.wizards.XPathChoosePage.createPageCustomControl(XPathChoosePage.java:109)
at org.eclipse.datatools.connectivity.oda.design.ui.wizards.DataSetWizardPage.createControl(DataSetWizardPage.java:123)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:669)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1083)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1142)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog.java:1139)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.java:1128)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1126)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:820)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.birt.report.designer.ui.actions.NewDataSetAction.createNewDataSet(NewDataSetAction.java:157)
at org.eclipse.birt.report.designer.ui.actions.NewDataSetAction.run(NewDataSetAction.java:142)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
FUDForum. Page generated in 0.07765 seconds
