Home » Modeling » Graphiti » Connection with given point array
Connection with given point array [message #1080756] Tue, 06 August 2013 10:47 Go to next message
John Cole is currently offline John ColeFriend
Member
Hello everyone,
I am trying to add a connection, which runs through some predefined points, which are stored in an array.
So actually I am trying to do this in the AddConnectionFeature. My code looks like this:
public PictogramElement add(IAddContext context, int[] points) {
	IAddConnectionContext addConContext = (IAddConnectionContext) context;
	IPeCreateService peCreateService = Graphiti.getPeCreateService();
	IGaService gaService = Graphiti.getGaService();
	ConnectClause clause = (ConnectClause) context.getNewObject();
	Connection connection = peCreateService.createFreeFormConnection((Diagram) context.getTargetContainer());
	connection.setStart(addConContext.getSourceAnchor());
	connection.setEnd(addConContext.getTargetAnchor());
	Polyline polyline = gaService.createPolyline(connection, points);
	polyline.setLineWidth(3);
	return connection;
Although I assign the array with the points to the method createPolyline, it has no effect and the break points are not visible.
What am I doing wrong?
Thanks in advance!
[Updated on: Wed, 07 August 2013 09:21]
Report message to a moderator
Re: Connection with given point array [message #1081616 is a reply to message #1080756] Wed, 07 August 2013 13:14 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
John,
You need to set the bendpoints in the FreeFormConnection using getBendpoints().add(Point) - no need for a Polyline here
HTH,
Bob
Re: Connection with given point array [message #1082234 is a reply to message #1081616] Thu, 08 August 2013 09:24 Go to previous message
Member
Bob,
thank you very much! Now it works!
Previous Topic:Connections inside ContainerShapes
Next Topic:are context buttons available for connections?
Current Time: Mon Sep 21 17:35:31 GMT 2020
Powered by FUDForum. Page generated in 0.02192 seconds
