Re: [EOL] polishing genmodel [message #1080193 is a reply to message #1079518] |
Mon, 05 August 2013 15:41 |
Looking at the GenModel EPackage in the EPackage registry, this should work:
GenModel!GenModel.all.first.colorProviders = true;
I've tried this on a simple metamodel and it worked for me. I have attached an example project.
Re: [EOL] polishing genmodel [message #1081477 is a reply to message #1080979] |
Wed, 07 August 2013 09:24 |
The different look and feel may be just because I run Eclipse from Linux, which uses a different theme than in Windows.
Have you tried selecting the GenModel EClass? Not the EPackage, but the class itself, which is a bit down from the GenDecoration you selected in your second screenshot.
According to the Plug-in Selection Explorer (click on the EPackage Registry view and press Shift+Alt+F1), the view is provided by the org.eclipse.epsilon.dt.epackageregistryexplorer plugin.
FUDForum. Page generated in 0.03774 seconds
