Home » Eclipse Projects » Gemini » ATTN: Gemini Blueprint subproject about to be shut down!
ATTN: Gemini Blueprint subproject about to be shut down! [message #1078105] Fri, 02 August 2013 14:46 Go to next message
Michael Keith is currently offline Michael KeithFriend
The subject of this topic describes the most likely outcome now that the subproject lead has moved on. Since nobody has stepped in to volunteer to lead the Gemini Blueprint subproject (formerly Spring DM) the subproject will be terminated/sit in hibernation, with no development, maintenance or support.
If you use Gemini Blueprint and/or are interested in becoming the lead please make it known ASAP either by replying to this post or by emailing the common Gemini dev mailing list (gemini-dev@eclipse.org). No experience is necessary, but either a knowledge of, or willingness to learn about the project is obviously going to help! The time commitment depends upon the volunteer, but a couple of hours a week is an estimated minimum.
Thank you.
-Mike Keith
Gemini parent project lead
PS Note that Gemini DBAccess, Gemini JPA, Gemini Web and Gemini Naming are still very much active projects with project leads and committers.
Re: ATTN: Gemini Blueprint subproject about to be shut down! [message #1078167 is a reply to message #1078105] Fri, 02 August 2013 16:20 Go to previous messageGo to next message
Dmitry Sklyut is currently offline Dmitry SklyutFriend
Mike,
If no one more qualified steps up - I would be willing to help here. We use it too much to see it die.
Dmitry
Re: ATTN: Gemini Blueprint subproject about to be shut down! [message #1078171 is a reply to message #1078167] Fri, 02 August 2013 16:23 Go to previous message
If you use it then you are already pretty qualified! Smile
Let's talk offline on the gemini-dev list, okay?
-Mike
Previous Topic:GeminiBlueprint 1.0.2 and GeminiWeb 2.2.2
Next Topic:DispatcherServlet doesn't initialize within web.xml
Current Time: Sat Dec 14 05:16:01 GMT 2024
Powered by FUDForum. Page generated in 0.03261 seconds
