Testing the close application without save [message #1077973] |
Fri, 02 August 2013 11:29 |
I have an RCP application and I would like to test the close or restart of my application. However, sometimes I will restart my application with some unsaved modifications in this case I have a popup menu to save (or not) my modifications.
So, I have different problems:
1/ When I use the action "ub_app_restart" my popup menu doesn't appear.
2/I've try to use "up_app_prepareForAUTTermination" and "ub_app_SynchronizeAUTTerminationAndRe-start" in this order :
Option Menu File/Restart =>Prepare to termination =>Validate the save =>Synchronize
But my test fail at the second step (ub_app_prepareForAUTTermination) with an "Action Error" and the description "Operation not supported by the selected toolkit". My problem sounds like this thread : http://www.eclipse.org/forums/index.php/t/494830/
I don't understand why I have this error ?
3/ I've also try to select the entry 'restart' in the menu bar and check if the save window exist, if not I click on 'yes' or 'no' button and retry the check but my test is always in execution and never stop...
Have you any idea to help me to test the restart of my application ?
Thanks for any help
Elise Ruelle
ALL4TEC
Re: Testing the close application without save [message #1080814 is a reply to message #1080732] |
Tue, 06 August 2013 11:56 |
Ok, thank you for your explanation about the restart option. But I've also tried with the "File/Exit" and I have the same result.
I have also tried the option "File/Restart" (and "File/Exit") without the two new actions and my test failed too when I tried to check if my popup message exist or not.
So, my question is how can I close/start or restart my application and have no error in my test ?
Thanks for your help
Elise Ruelle
ALL4TEC
FUDForum. Page generated in 0.02446 seconds
