Home » Modeling » TMF (Xtext) » Class not found exception in packaged plug-in. Xtext file .ui generate
Class not found exception in packaged plug-in. Xtext file .ui generate [message #1076896] Thu, 01 August 2013 01:42 Go to next message
Mayerli Romero is currently offline Mayerli RomeroFriend
Hello
I'm package a plugin made for me called mView. I create my plug in using xtext and it generate 2 files more than my original project (mView.test and mView.ui) I have a problem with deploying of my packaged plug-in (i.e., when it is not started in a runtime workbench).
The error is:
Plug-in mView.ui was unable to load class org.xtext.example.mydsl.ui.MViewExecutableExtensionFactory.
org.eclipse.core.runtime.CoreException: Plug-in mView.ui was unable to load class org.xtext.example.mydsl.ui.MViewExecutableExtensionFactory. at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at ..... Caused by: java.lang.ClassNotFoundException: org.xtext.example.mydsl.ui.MViewExecutableExtensionFactory at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) ....
I already ensure of the jdk and jre compatibility and all its ok. In the part of the MANIFIEST of the plug-in I already check the jar file that contains the plug-in classes and be listed in the Bundle-ClassPath. In the dependency's of the plug-in appears xtext and in the file built.properties is check the source folder in SourceBuild and BinaryBuild, but I can't find it more to do, I would greatly appreciate your help.
sorry for my English. Thank You!
PD: just for information. I package my plug-in following this turorial: http: //www.vogella.com/ articles/ EclipsePlugIn/ article.html#p2deployplugin_overview
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1076922 is a reply to message #1076896] Thu, 01 August 2013 02:40 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi can you please share your code
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1077387 is a reply to message #1076922] Thu, 01 August 2013 16:16 Go to previous messageGo to next message
I already fix it. The proyects that xtext generate mView.test and mView.ui dont have the built.properties file. I copy this file of the principal proyect, paste and modify in each project. And it works!... Thank You Smile
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766746 is a reply to message #1076922] Mon, 26 June 2017 17:09 Go to previous messageGo to next message
Christian Schulze is currently offline Christian SchulzeFriend
Hi Christian,
I got the same issue within my project (on branch master):
https://github.com/marc-christian-schulze/structs4java
Could you please have a look at the sources?
I already checked the build.properties files but they seem to be ok.
Best regards
Christian
[Updated on: Mon, 26 June 2017 17:11]
Report message to a moderator
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766747 is a reply to message #1766746] Mon, 26 June 2017 17:25 Go to previous messageGo to next message
for me it looks like the complete maven config is broken (config of source folders etc ...)
this might be caused by not checking in .classpath /.project files
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766748 is a reply to message #1766747] Mon, 26 June 2017 18:08 Go to previous messageGo to next message
i just built with pure maven and not importing anything into eclipse and it worked fine after installing into a eclipse.
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766924 is a reply to message #1766748] Wed, 28 June 2017 18:24 Go to previous messageGo to next message
Seems I found my mistakes:
1. Eclipse Configuration not generated by m2e-Connector:
My assumption was that the m2e plugin has a connector to configure Eclipse properly for the xtext plugin but it didn't.
But copying the example configuration from your github project resolved almost all error markers:
https://github.com/xtext/maven-xtext-example
2. Forgot to install the MWE 2 language SDK:
After copying the Eclipse configuration only the following error message was left:
"Bundle org.eclipse.emf.mwe2.launch cannot be resolved"
After some web crawling I read in the following article that I missed to install the "MWE 2 language SDK" plugin:
https://www.eclipse.org/forums/index.php/t/164527/
But after that Eclipse gladly runs my plugin in the debugger. :)
Best regards
Christian
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766925 is a reply to message #1766748] Wed, 28 June 2017 18:24 Go to previous messageGo to next message
Best regards
Christian
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766926 is a reply to message #1766748] Wed, 28 June 2017 18:25 Go to previous messageGo to next message
Best regards
Christian
Re: Class not found exception in packaged plug-in. Xtext file .ui generate [message #1766927 is a reply to message #1766748] Wed, 28 June 2017 18:25 Go to previous message
Best regards
Christian
Previous Topic:Problem with external ecore model
Next Topic:X-Text Linking Services
Current Time: Tue Oct 26 06:43:09 GMT 2021
Powered by FUDForum. Page generated in 0.01727 seconds
