Re: Unhandled event loop exception ,No more handles [message #1076448 is a reply to message #1076247] |
Wed, 31 July 2013 12:08 |
Ed Merks Messages: 33140 Registered: July 2009 |
It sounds like something is leaking window handles. I've not sen that
with just the Eclipse IDE itself, so most likely an Android-specific
issue best asked about on an Android-specific forum...
On 31/07/2013 1:33 PM, Hong xclover wrote:
> The OS of my computer is Windows 7 64bit.
> Android SDK and eclipse are from
> adt-bundle-windows-x86_64-20130717.zip which is downloaded from the
> android developer guide website.
> My problem is when I click from the Package explorer on the left to
> anywhere in an opened file in the workbench,error dialog will
> occur,the error info is below:
> No more handles
> After I click OK button,then it will show another dialog that ask me
> whether I want to exit the workbench or not.
> Is anyone who in troble with this problem? Is there any solution to it?
> More error info is below:
> Session Data:
> eclipse.buildId=v22.0.4-741630
> java.version=1.7.0_25
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
> Framework arguments: -product
> com.android.ide.eclipse.adt.package.product
> Command-line arguments: -os win32 -ws win32 -arch x86_64 -product
> Exception Stack Trace:
> org.eclipse.swt.SWTError: No more handles
> at org.eclipse.swt.SWT.error(SWT.java:4387)
> at org.eclipse.swt.SWT.error(SWT.java:4276)
> at org.eclipse.swt.SWT.error(SWT.java:4247)
> at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
> at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
> at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
> at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
> at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
> at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
> at
> org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
> at
> org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
> at
> org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:327)
> at
> org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:265)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:243)
> at
> org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:172)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:193)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:191)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:596)
> at
> org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
> at
> org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
> at
> org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
> at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
> at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
> at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
> at
> org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
> at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
> at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
> at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
> at
> org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
> at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
> at
> org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
> at
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Ed Merks
Re: Unhandled event loop exception ,No more handles [message #1080851 is a reply to message #1080272] |
Tue, 06 August 2013 12:58 |
James,
If this was just a pervasive problem, everyone would see it... What
else, if anything, do you have installed in the base package you
downloaded from Eclipse?
On 06/08/2013 2:48 PM, James Karavias wrote:
> I've recently begun having this error as well. I upgraded to kepler
> from juno just before it started happening. Now, after having removed
> all of eclipse from my environment (at least I think I did) I
> reinstall Juno and immediately experience this issue. Note that this
> isn't an Android development box. Any new information on this problem?
> Here's my stack trace:
> eclipse.buildId=M20130204-1200
> java.version=1.7.0_04
> BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
> Framework arguments: -product org.eclipse.epp.package.java.product
> Error
> Mon Aug 05 11:04:09 PDT 2013
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Ed Merks
Re: Unhandled event loop exception ,No more handles [message #1081011 is a reply to message #1080972] |
Tue, 06 August 2013 17:27 |
James,
If you have reproducible steps, please outline them carefully and open a
bugzilla. Please try to reproduce it minimally, i.e., just with one of
the download packages and test what additional things you must install
for the problem to start appearing. I really doubt that JDT is the
source of the problem; once you run out of window handles, the problems
will appear everywhere, and everyone would be complaining. So you see
the problem in Juno? You probably should try Kepler instead then...
On 06/08/2013 6:24 PM, James Karavias wrote:
> Ed,
> Thanks for asking that so gently. :blush:
> The package I've installed is Eclipse for Java EE developers (Juno).
> Windows 64bit. Its strictly the package as downloaded. I have had
> other versions on this machine but believe I've eliminated any
> remnants of them. This morning the way I reproduced it was to create a
> new workspace, import a maven project, open the package explorer and a
> source file in the java editor (not WindowBuilder) and then click
> somewhere in the package explorer panel, then back in the java
> editor. It happens every time. It doesn't seem to matter which
> editor I'm using. I can get it to happen by editing the POM
> Possibly relevant is that I had been seeing situations in my prior
> install where windows were not repainting completely or that moving
> the mouse pointer along packages in the explorer would result in the
> package names dissappearing.
> It doesn't produce the exact same stack trace each time. Deeper stack
> frames vary by which widget is being updated.
> I am using this on a Lenovo W520 with 16gb running Windows 7 pro. SP
> 1. Displaying on 3 monitors. The GPU is NVIDIA Quadro 1000M; driver
> version 9.18.13.593.
> What additional information would be helpful?
> Jim
Ed Merks
FUDForum. Page generated in 0.09047 seconds
