Re: GeminiBlueprint 1.0.2 and GeminiWeb 2.2.2 [message #1076650 is a reply to message #1076611] |
Wed, 31 July 2013 17:41  |
Robert Breitling Messages: 4 Registered: July 2013 |
I little more information. It turns out the FileInstall bundle can not deal with the this jar file: org.eclipse.jdt.core.compiler.batch-3.8.0.I20120518-2145.jar. It's not a bundle but works if its in the root directory of my bundle path (if that makes sense). It must patch the jasper compiler in some way and is definitely required.
Interestingly, Equinox does not suffer from this problem. In my tests, I had my bundles organized using those same sub-directories as I was using with the FileInstall bundle with Felix, but Equinox loaded that jar just fine from the sub-directory.
I neat little difference between the two frameworks!
Bob
[Updated on: Wed, 31 July 2013 18:07] Report message to a moderator
FUDForum. Page generated in 0.02377 seconds
