Home » Eclipse Projects » Eclipse Scout » Desktop aplication and web aplication.(my deplay is not working)
Desktop aplication and web aplication. [message #1075955] Tue, 30 July 2013 11:55 Go to next message
Santo Mota is currently offline Santo MotaFriend
Member
hi bodys, i think scout has a great future.
My scout aplication run so well, exceptly when i do a deploy.
Iam using Tomtac 7.
eclipse kepler.
inside the browser, the only thing that can see is the page where i am able to download the client aplication.
the problem continue if i use de client aplication. see the image ...
this is the message in the log file.
"!ENTRY org.eclipse.equinox.app 0 0 2013-07-30 01:31:01.747
!MESSAGE Product org.eclipse.helloworld.ui.swt.product could not be found."
i let the log file attached.
I appreciate your help.
Re: Desktop aplication and web aplication. [message #1075971 is a reply to message #1075955] Tue, 30 July 2013 12:26 Go to previous messageGo to next message
Ivan Motsch is currently offline Ivan MotschFriend
can you show the contents of the WEB_INF/eclipse/configuration/config.ini as well as the plugin and folder names that are in the WEB_INF/eclipse/plugins Folder.
In Windows you can therefore simply go to command window (CMD) and type
dir /b C:/path-to-tomcat/webapps/your-app/WEB-INF/eclipse/plugins
and the past the result into this forum post.
Most likely there is a missing launcher bundle or a missing update.configuration bundle.
The log talks about such missing dependency.
Re: Desktop aplication and web aplication. [message #1075994 is a reply to message #1075971] Tue, 30 July 2013 13:30 Go to previous messageGo to next message
Member
ok, i did what you encourage me, and i let the files attached.
i was trying to read the file but its just about .jar and i didn't know what to with.
  • Attachment: config.ini
    (Size: 1.34KB, Downloaded 243 times)
  • Attachment: dir_b_.txt
    (Size: 1.73KB, Downloaded 459 times)
Re: Desktop aplication and web aplication. [message #1076006 is a reply to message #1075994] Tue, 30 July 2013 14:05 Go to previous messageGo to next message
Jeremie Bresson is currently offline Jeremie BressonFriend
Sidenote:
For webapplication (Scout RAP client) you need to deploy the server war and the rap war.
More informations:
http://www.eclipse.org/forums/index.php/t/491595/
[Updated on: Tue, 30 July 2013 14:06]
Report message to a moderator
Re: Desktop aplication and web aplication. [message #1076013 is a reply to message #1075955] Tue, 30 July 2013 14:17 Go to previous messageGo to next message
Thanks, the serverside looks great.
Can you give me config.ini and dir /B also for the Client/Gui side?
I assume you are using SWT?
Did you export the following product or which one was it?
/org.eclipse.helloworld.ui.swt/products/production/helloworld-swt-client.product
Re: Desktop aplication and web aplication. [message #1076046 is a reply to message #1076013] Tue, 30 July 2013 15:27 Go to previous messageGo to next message
Member
Ivan Motsch wrote on Tue, 30 July 2013 10:17
look this what i found!
and yes, thats my export
[Updated on: Tue, 30 July 2013 15:38]
Re: Desktop aplication and web aplication. [message #1079052 is a reply to message #1076046] Sun, 04 August 2013 01:03 Go to previous messageGo to next message
Member
well. thanks everybody who helped me in this thread.
I got a solutions, I had to changing the whole eclipse project, i downloaded the eclipse scout solutions, and when i deploy my aplication, everything is ok.
thanks.
Re: Desktop aplication and web aplication. [message #1079521 is a reply to message #1079052] Sun, 04 August 2013 18:39 Go to previous message
Nice to hear this... Thanks for your feedback.
Previous Topic:AbstractForm newly created ID
Next Topic:Use of ListBox with a lookupcall
Current Time: Tue Apr 16 19:25:21 GMT 2024
Powered by FUDForum. Page generated in 1.03964 seconds
