Home » Modeling » EMF » [CDO - MySQL] java.util.concurrent.TimeoutException(Connectivity issue with MySQL adapter for CDO)
[CDO - MySQL] java.util.concurrent.TimeoutException [message #1075378] |
Mon, 29 July 2013 10:23 |
Konstantinos Barmpis Messages: 12 Registered: July 2013 |
To whom it may concern,
I am trying to configure CDO-MySQL to a new installation of Kepler (With Eclipse Modeling Tools).
I am able to run the client + server as per the tutorial (http://wiki.eclipse.org/CDO/User_Contributed_Documentation - An Introduction to CDO 4.0 (by Vincenzo Caselli, RCPVision)) but when I try to commit a transaction (even one with only a single model element in it, either using the CDO session UI, or programmatically) I get:
org.eclipse.emf.cdo.common.util.TransportException: java.util.concurrent.TimeoutException
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:526)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393)
at org.eclipse.emf.internal.cdo.session.DelegatingSessionProtocol.commitTransaction(DelegatingSessionProtocol.java:292)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:72)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1191)
at org.eclipse.emf.cdo.internal.ui.editor.CDOEditor$22.run(CDOEditor.java:1845)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:257)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
... 6 more
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
at org.eclipse.net4j.buffer.BufferInputStream.computeTimeout(BufferInputStream.java:216)
at org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:189)
at org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
at java.io.DataInputStream.readBoolean(Unknown Source)
at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readBoolean(ExtendedDataInput.java:60)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirmingCheckError(CommitTransactionRequest.java:304)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:290)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:1)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117)
at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
... 11 more
In case it is of use, the server initializes normally with:
[INFO] CDO server starting
!SESSION 2013-07-29 10:59:44.943 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.emf.cdo.server.product.tcp_h2
Command-line arguments: -product org.eclipse.emf.cdo.server.product.tcp_h2 -data D:\workspace-cdo/../runtime-CDO-Server.product -dev file:D:/workspace-cdo/.metadata/.plugins/org.eclipse.pde.core/CDO-Server.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-07-29 10:59:45.565
!MESSAGE CDO server starting
[WARN] Detected crash of repository demo
!ENTRY org.eclipse.emf.cdo.server.db 2 0 2013-07-29 10:59:46.087
!MESSAGE Detected crash of repository demo
[INFO] Repaired crash of repository demo: lastObjectID=OID2, nextLocalObjectID=OID9223372036854775807, lastBranchID=0, lastCommitTime=1,374,766,710,269, lastNonLocalCommitTime=1,374,766,710,269
!ENTRY org.eclipse.emf.cdo.server.db 1 0 2013-07-29 10:59:46.101
!MESSAGE Repaired crash of repository demo: lastObjectID=OID2, nextLocalObjectID=OID9223372036854775807, lastBranchID=0, lastCommitTime=1,374,766,710,269, lastNonLocalCommitTime=1,374,766,710,269
[INFO] Net4j extension starting
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-07-29 10:59:46.288
!MESSAGE Net4j extension starting
[INFO] Net4j extension started
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-07-29 10:59:46.318
!MESSAGE Net4j extension started
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-07-29 10:59:46.319
!MESSAGE CDO server started
Computer Software Setup:
Windows 7 - 64bit
Eclipse Modeling Tools 2.0.0.20130613-0530
with: CDO Model Repository EPP 4.2.0.v20130613-1556
using: Net4j DB Framework MYSQL Adapter 4.2.0.v20130601-1611
running: MySQL server 5.5
Config file (cdo-server.xml):
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2038">
</acceptor>
<repository name="demo">
<store type="db">
<mappingStrategy type="horizontal"/>
<dbAdapter name="mysql"/>
<dataSource
class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
url="jdbc:mysql://localhost:2038/cdotest?createDatabaseIfNotExist=true"
user="root"
password="admin"
<property name="drop" value="true"/>
</store>
</repository>
</cdoServer>
As far as I understand this may be due to an error in communication of the CDO client to the CDO server (unless the server initializes normally but then cannot communicate with the MySQL service). In either case, I do not know how to proceed to solve this.
Please let me know if you need any more diagnostics,
Thank you in advance for any help or pointers to solutions,
Yours faithfully,
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1075396 is a reply to message #1075378] |
Mon, 29 July 2013 10:56 |
Am 29.07.2013 12:23, schrieb Konstantinos Barmpis:
Are you sure that server and clients use the same (versions of the) binaries?
Does the server log any warnings or exceptions at the same time?
Can you load/navigate models on your client?
Please try to add the following to the <repository> element of teh cdo-server.xml:
<property name="optimisticLockingTimeout" value="10000"/>
Does that help?
Cheers
/Eike
http://www.esc-net.de
> at
> at
> ... 6 more
> at
> at
> ... 11 more
> Windows 7 - 64bit
> <cdoServer>
> </acceptor>
> <store type="db">
> <dataSource
> user="root"
> password="admin"
> </store>
> </repository>
> </cdoServer>
> Yours faithfully,
Cheers
/Eike
Re: [CDO - MySQL] java.util.concurrent.TimeoutException [message #1075605 is a reply to message #1075571] |
Mon, 29 July 2013 18:23 |
Am 29.07.2013 18:55, schrieb Konstantinos Barmpis:
> Thank you for your prompt response:
> There seems to be no communication at all happening.
Hmm, how would that be related to the chosen database type? That only makes sense if the time is really being spent in
Mysql. I wonder if you can debug/step through the server, starting with a breakpoint in
Repository.commit(InternalCommitContext, OMMonitor)...
Cheers
/Eike
> I cannot commit any changes so cannot test any model loading or navigation.
> Using the CDO Session UI I can virtually add model elements (and nest/navigate them from the editor) but then cannot
> persist them.
> I have added this, and also a similar line in the client app, doesn't seem to help.
> For now I am working with the embedded H2 store as it works as expected, but it would be nice to work with MySQL if I
> can resolve this.
Cheers
/Eike
Current Time: Wed Apr 24 21:31:37 GMT 2024
Powered by FUDForum. Page generated in 0.03474 seconds
