Home » Archived » Hudson » NoClassDefFoundError: com/sun/xml/txw2/TypedXmlWriter
NoClassDefFoundError: com/sun/xml/txw2/TypedXmlWriter [message #1075252] Mon, 29 July 2013 05:55 Go to next message
Simon Kissane is currently offline Simon KissaneFriend
Using Hudson 3.0.1-b2
I create a dummy job called "test".
I go to URL /job/test/api
It contains a link "Schema" which points to
/job/test/api/schema
This displays a 500 error:
java.lang.NoClassDefFoundError: com/sun/xml/txw2/TypedXmlWriter
Is there any way to fix this? Is it a bug?
Simon
Re: NoClassDefFoundError: com/sun/xml/txw2/TypedXmlWriter [message #1077678 is a reply to message #1075252] Fri, 02 August 2013 02:19 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
Looks like a bub. Please file a bug
Winston Prakash
Eclipse Hudson team
Re: NoClassDefFoundError: com/sun/xml/txw2/TypedXmlWriter [message #1086426 is a reply to message #1077678] Wed, 14 August 2013 07:36 Go to previous messageGo to next message
Actually this seems to match bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=402338
Is that fixed in version 3.0.1? The bug database isn't very clear.
Re: NoClassDefFoundError: com/sun/xml/txw2/TypedXmlWriter [message #1090319 is a reply to message #1086426] Tue, 20 August 2013 01:34 Go to previous message
It is fixed in 3.1.0. You can check it here
http://ci.hudson-ci.org/perf_sandbox/api/schema
Winston Prakash
Eclipse Hudson team
Previous Topic:Suppressing symbolic links
Next Topic:Git "Clean after checkout" does not clean folders
Current Time: Sat Jul 24 21:40:48 GMT 2021
Powered by FUDForum. Page generated in 0.02196 seconds
