Home » Eclipse Projects » Eclipse 4 » accessing resources from other plugin in Application.e4xmi
accessing resources from other plugin in Application.e4xmi [message #1073978] Thu, 25 July 2013 22:02 Go to next message
Ralf Heydenreich is currently offline Ralf HeydenreichFriend
Hi all,
I want to use an icon in my Application.e4xmi from an other plugin which
I've created. But if I write e.g.
platform:/plugin/de.my.own.resourcesplugin/icons/16/app_16.png
for Icon URI the Application editor complaints about "missing path". How
can I expose the icons from my plugin for others?
Thanks in advance,
Ralf.
Re: accessing resources from other plugin in Application.e4xmi [message #1073999 is a reply to message #1073978] Thu, 25 July 2013 23:01 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph CarrollFriend
You should be able to, though you should either have an explicit dependency on your resourcesplugin or have a way to handle missing images to avoid the ugly red square.
With that said, what is the exact error message you are getting?
JD
Re: accessing resources from other plugin in Application.e4xmi [message #1074025 is a reply to message #1073999] Fri, 26 July 2013 00:25 Go to previous messageGo to next message
Am 26.07.2013 01:01, schrieb Joseph Carroll:
> JD
Hi Joseph,
the exact message is "the system cannot find the path specified". What
I've now tried is to select the real path in my plugin in, i.e.
platform:/plugin/de.my.own.resourcesplugin/src/main/resources/icons/16/app_16.png
which is really ugly (but working!). If I build that plugin with Maven
(Tycho) than the correct structure is generated:. The resulting jar file
has the following directories (1st level):
<root>
/de
/icons
/META-INF
/OSGI-INF
How can I fix that?
Ralf.
Re: accessing resources from other plugin in Application.e4xmi [message #1074183 is a reply to message #1074025] Fri, 26 July 2013 08:35 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
This directory is only available at dev-time and once you export your
project it won't be found.
The problem you have is a mismatch between your structure in eclipse
where icons are located in "src/main/resources/icons" and
runtime-classpath where it is "icons/...".
My wild guess is that if you start the application inside eclipse with
the path
"platform:/plugin/de.my.own.resourcesplugin/icons/16/app_16.png" it will
work although the tooling editor tells you the icon is not found (it
does not know about the classpath)!
Like in my other answer to your ResourceProvider problem I'd suggest you
move away from your maven story and put the icons into an icons folder
directly below your plugin dir.
So your layout in Eclipse looks like this:
src
de
icons
and add icons to your build.properties and let PDE manage your project
and maven-tycho build it.
Tom
>> JD
> Hi Joseph,
> <root>
> /de
> /icons
> /META-INF
> /OSGI-INF
> How can I fix that?
> Regards,
> Ralf.
Re: accessing resources from other plugin in Application.e4xmi [message #1074368 is a reply to message #1074183] Fri, 26 July 2013 15:31 Go to previous message
Couldn't have said it better.
Previous Topic:Accessing/updating UI elements in other Parts + best practices?
Next Topic:Eclipse Kepler Dependency Injection in 3.x & Views
Current Time: Fri Apr 03 08:05:57 GMT 2020
Powered by FUDForum. Page generated in 0.05342 seconds
