Indexer issue with templates that use templates [message #1073470] |
Wed, 24 July 2013 21:41 |
Scott Sikora Messages: 1 Registered: July 2013 |
Junior Member |
I am having an issue with the indexer where it cannot resolve a method of a template that is called from another template. The issue is related to a template using its own template parameter as a template parameter into a member variable, which is a template itself. Code navigation is less than optimal with this issue.
Does anyone know why this is? I verified that this used to work fine in an older version of eclipse (see below), which makes me think I broke it when messing with the settings. I tried a fresh copy of eclipse CDT but it has the same issue. The code compiles fine using gcc 4.7.2 (mingw).
Details:
In the file "Test_cpp.cpp" line 16 column 22, select Navigate->Open Declaration to go directly to the header file of this function.
It fails if I try the same thing in "Template01.cpp" line 14 column 24 with the following error: Could not find symbol 'Get' in index.
Fresh Version:
Eclipse CDT
Version: Kepler Release
Build id: 20130614-0229
Older Version:
Eclipse IDE for C/C++ Developers
Version: Indigo Service Release 1
Build id: 20110916-0149
1.4.1.20110909-1818
FUDForum. Page generated in 0.01794 seconds
