Home » Eclipse Projects » BIRT » Does BIRT support XPath Axes?
Does BIRT support XPath Axes? [message #1073293] Wed, 24 July 2013 13:33 Go to next message
Paolo Aprile is currently offline Paolo AprileFriend
Hi again!
I'm trying to select data from an XML data source, but it doesn't seem to support the use of XPath axes.
Given an XML like this (courtesy of Zvom XLab):
<AAA>
<BBB aaa="111" bbb="222">
<CCC/>
<CCC xxx="555" yyy="666" zzz="777"/>
</BBB>
<BBB aaa="999">
<CCC xxx="qq"/>
<DDD xxx="ww"/> //--->This xxx is the attribute I want to select
<EEE xxx="oo"/>
</BBB>
<BBB>
<DDD xxx="oo"/>
</BBB>
</AAA>
I'm mapping a column with something like this:
//CCC[@xxx="qq"]/following-sibling::DDD/@xxx
While in the XLab and elsewere it works perfectly, in BIRT I only obtain a void column.
Does anyone know if this syntax is supported?
Thanks!
Paolo
Edit:
I tried this solution, that doesn't involve any XPath functions and should be supported:
/AAA/BBB/CCC[@xxx="qq"]/../DDD/@xxx
Again, no result. While it works in other contexts, it doesn't recover any data in BIRT. Sad
Any suggestions?
[Updated on: Thu, 25 July 2013 08:28]
Report message to a moderator
Re: Does BIRT support XPath Axes? [message #1075318 is a reply to message #1073293] Mon, 29 July 2013 08:19 Go to previous messageGo to next message
No answer at all?... Should I be worried? O_o
Re: Does BIRT support XPath Axes? [message #1076476 is a reply to message #1075318] Wed, 31 July 2013 13:00 Go to previous message
Ok, upon further research online, I've found traces of this problem since 2009.
It appears that more complex XPath patterns seimply do not work in BIRT. Even being sintattically correct, no results are produced.
I find it hard to believe that no one on this forum knew about the problem. :/
Previous Topic:Add link to Maximo page to launch report in "Browser View"
Next Topic:barcode via Dynamic Image
Current Time: Mon Jan 20 04:39:48 GMT 2020
Powered by FUDForum. Page generated in 0.01926 seconds
