Home » Archived » AMW » Woven Panel Extension [Solved]
Woven Panel Extension [Solved] [message #1072986] Tue, 23 July 2013 22:18 Go to next message
Giacomo Lamonaco is currently offline Giacomo LamonacoFriend
Hi all,
I'm working on a project where a tree editor is generated with emf: we have the usual .edit and .editor folder. Suppose that this project is called Sa.
Now i would to 'integrate' this editor with the default woven panel provided by the AMW plugins.
I'm trying to extend the DefaultWovenModelPanel class: specifically, i'm modifying the createViewer method only by adding the SaItemProviderAdapterFactory to the adapterFactory. This Class is under the .edit folder, under the .provider package.
In the plugin content, i add as dependency org.eclipse.gmt.weaver and org.eclipse.gmt.weaver. In the extension content, i add the wovenPanelID extension point, and i refer to the extension of DefaultWovenModelPanel class, defined above.
During the wizard, i can choose the WovenPanel extended , but when i open the weaver editor i don't see any modifications (e.g the modified icons): it appears like the default woven panel.
How can i solve it?
[Updated on: Sun, 18 August 2013 09:38]
Report message to a moderator
Re: Woven Panel Extension [message #1073020 is a reply to message #1072986] Wed, 24 July 2013 00:49 Go to previous messageGo to next message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del FabroFriend
The following link has a documentation about the wovenPanelId extension point: http://dev.eclipse.org/viewsvn/viewvc.cgi/plugins/trunk/org.eclipse.gmt.weaver.doc.developer/?root=Modeling_AMW&pathrev=22
Did the panel implements the interface IWovenModelPanel ?
It seems that it failed to instantiate the woven panel, but I cannot see the reason.
Did you have any error in the Eclipse error log?
Marcos.
Re: Woven Panel Extension [message #1086466 is a reply to message #1073020] Wed, 14 August 2013 08:38 Go to previous message
Hi Marcos,
thank you for your reply.. you're right! I had problems with my eclipse installation: using the AMMA bundle everything works.
Thank You!
Previous Topic:Validating links
Next Topic:Mwcore validation
Current Time: Fri Aug 07 22:29:32 GMT 2020
Powered by FUDForum. Page generated in 0.02021 seconds
