Home » Modeling » Graphiti » Creating a new Diagram
Creating a new Diagram [message #1072355] Mon, 22 July 2013 15:29 Go to next message
Thomas Thonhofer is currently offline Thomas ThonhoferFriend
Hello
I have created an editor with Graphiti. So far i have only tested it with the default Graphiti Wizard, creating the standard .diagram file. Now I want to use my own wizard to create a custom file, containing a diagram and open my editor. I already have a wizard that creates a file. What I don't know is, how I should create a new diagram of my existing diagram type, use the file as a resource for it and open my editor. I already have a subclass of DiagramEditor, but I have no idea how to use it for creating my custom diagram. I didn't find any real help so far.
Below is the performFinish method of my wizard. The diagram should be created within the createDiagram method of the DiagramCreator class. I just don't know what this method should look like.
public boolean performFinish() {
		final String fileName = page1.getFileName();
		final IResource container = page1.getDiagramContainer();
		IRunnableWithProgress op = new IRunnableWithProgress() {
			public void run(IProgressMonitor monitor) throws InvocationTargetException {
				try {
					IPath path = container.getFullPath().append(fileName);
					URI uri = URI.createPlatformResourceURI(path.toString(), true);
					DiagramCreator.createDiagram(uri, targetNamespace);
				} catch (CoreException e) {
					throw new InvocationTargetException(e);
				} finally {
					monitor.done();
		try {
			getContainer().run(true, false, op);
		} catch (InterruptedException e) {
			return false;
		} catch (InvocationTargetException e) {
			Throwable realException = e.getTargetException();
			MessageDialog.openError(getShell(), "Error", realException.getMessage());
			return false;
		return true;
I really hope someone can help me out. If possible, some code snippets or a comprehensible example would be very appreciated.
Thank you.
Re: Creating a new Diagram [message #1072775 is a reply to message #1072355] Tue, 23 July 2013 13:20 Go to previous messageGo to next message
Andrej K is currently offline Andrej KFriend
hey i hope I can help you and understood your question right
here a snippet:
private static String diagramEditorId="...";//you should read this two from your plugin xml file
private static String diagramTypeId ="...";//ive find out how i can open it in graphiti examples
public static void openMyEditor(...) {
// i have my own editorinput, it is handeld in my extended "DiagramEditor" class, cant write more about it
	IEditorInput input = new myEditorInput(...);
	String newName= "name of the new diagram which should be created";
	//create an Diagram
	final Diagram diagram = Graphiti.getCreateService().createDiagram(diagramTypeId, newName, true);
	//Create an Graphiti File on given path
	URI fileURI = URI.createFileURI("Drive:\\Users\\...\\"+newName+".diagram");
	FileService.createEmfFileForDiagram(fileURI, diagram);
	//Open this Created file in Graphiti Editor
	try {
		page.openEditor(input, diagramEditorId);
	} catch (PartInitException e) {}
	//here you can write a method and add some element automaticaly, it works fine
Re: Creating a new Diagram [message #1073816 is a reply to message #1072355] Thu, 25 July 2013 14:39 Go to previous messageGo to next message
Thank you for your answer.
Based on that I have created a similar way for making a file and a diagram. The file is created and the editor opens. The problem is, that the pictogram elements I want to create afterwards, are not displayed. They are added to the diagram correctly, but I can not see them.
Any ideas what the problem could be?
Re: Creating a new Diagram [message #1073825 is a reply to message #1073816] Thu, 25 July 2013 14:56 Go to previous messageGo to next message
Hi!
how do you know that they are added correctly if you cant see them?
maybe that helps
after i created new diagram i make like this:(in extra method)
IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
IEditorPart myEditor= page.getActiveEditor();
if (myEditor instanceof myExtendedDiagramEditor ){
putThingsToEditorHandler.addElementEntityToEditor(myEditor,elemenToAdd,null);
in my handler i create a context and ask if I can add, if i can add so i add this element like:
CreateContext context = new CreateContext();
		context.setTargetContainer(((myExtendedDiagramEditor ) myEditor).getDiagramTypeProvider().getDiagram());
//put additional stuff if you want to context like context.putProperty(...);
if(((myExtendedDiagramEditor ) myEditor).getDiagramTypeProvider().getFeatureProvider().getCreateFeatures()[featureCall].canCreate(context)){
			((myExtendedDiagramEditor ) myEditor).getDiagramTypeProvider().getFeatureProvider().getCreateFeatures()[featureCall].create(context);
"[featureCall]" is some special element/create/feature number, maybe not the best solution but it works at first...
Re: Creating a new Diagram [message #1074236 is a reply to message #1072355] Fri, 26 July 2013 10:45 Go to previous messageGo to next message
Thanks, but unfortunately this does not solve my problem.
I know that the elements are created and added, because when I ask for the children of the diagram (by using diagram.getChildren() for example), I get the elements I created before.
Re: Creating a new Diagram [message #1075346 is a reply to message #1073816] Mon, 29 July 2013 09:09 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Thomas,
can you provide some code here that shows how you add the pictogram elements
and from where you do that?
Michael
Re: Creating a new Diagram [message #1077353 is a reply to message #1072355] Thu, 01 August 2013 15:26 Go to previous messageGo to next message
I use a normal add method for my pictogram elements, similar to the graphiti tutorial. It is called from the create method when I add a new Element.
	public PictogramElement add(IAddContext context) {
		final Activity addedClass = (Activity) context.getNewObject();
		final Diagram targetDiagram = (Diagram) context.getTargetContainer();
		if (addedClass.getId() == null){
		Activator activator = Activator.getDefault();
		Shell shell = activator.getWorkbench().getActiveWorkbenchWindow().getShell();
		InputDialog n = new InputDialog(shell, "ID input", "Please insert ID", "", null);
		n.open();
		addedClass.setId(n.getValue());
		// CONTAINER SHAPE WITH ROUNDED RECTANGLE
		final IPeCreateService peCreateService = Graphiti.getPeCreateService();
		final ContainerShape containerShape = peCreateService.createContainerShape(targetDiagram, true);
		// check whether the context has a size (e.g. from a create feature)
		// otherwise define a default size for the shape
		final int width = context.getWidth() <= 0 ? 120 : context.getWidth();
		final int height = context.getHeight() <= 0 ? 70 : context.getHeight();
		IGaService gaService = Graphiti.getGaService();
		RoundedRectangle roundedRectangle; // need to access it later
			// create and set graphics algorithm
			roundedRectangle = gaService.createRoundedRectangle(containerShape, 5, 5);
			roundedRectangle.setForeground(manageColor(FOREGROUND));
			roundedRectangle.setBackground(manageColor(BACKGROUND));
			roundedRectangle.setLineWidth(2);
			gaService.setLocationAndSize(roundedRectangle, context.getX(), context.getY(), width, height);
			// create link and wire it
			link(containerShape, addedClass);
			// SHAPE WITH LINE
				// create shape for line
				Shape shape = peCreateService.createShape(containerShape, false);
				Polyline polyline =	gaService.createPolyline(shape, new int[] { 0, 20, width, 20 });
				polyline.setForeground(manageColor(FOREGROUND));
				polyline.setLineWidth(2);
				// create shape for text
				// create and set text graphics algorithm
				Text text = gaService.createText(shape, addedClass.getId());
				text.setForeground(manageColor(TEXT_FOREGROUND));
				text.setHorizontalAlignment(Orientation.ALIGNMENT_CENTER );
				// vertical alignment has as default value "center"
				text.setFont(gaService.manageDefaultFont(getDiagram(), false, true));
				gaService.setLocationAndSize(text, -40, 20, width, 20);
				link(shape, addedClass);
			// SHAPE WITH TEXT
				Text text = gaService.createText(shape, "Activity");
				gaService.setLocationAndSize(text, 0, 0, width, 20);
			ChopboxAnchor ca = peCreateService.createChopboxAnchor(containerShape);
			link(ca, addedClass);
			// call the layout feature
			layoutPictogramElement(containerShape);
			return containerShape;
The method basically works when I use the default graphiti wizard. The problem of the pictogram elements not being added to the canvas, only occurs when I create and open my own diagram and file.
Re: Creating a new Diagram [message #1077942 is a reply to message #1077353] Fri, 02 August 2013 10:39 Go to previous messageGo to next message
Thomas,
can you provide the code how you create the new diagram and open the editor?
Michael
Re: Creating a new Diagram [message #1079905 is a reply to message #1072355] Mon, 05 August 2013 08:13 Go to previous messageGo to next message
For opening my editor I created my own PersistencyBehavior class and a loadDiagram method. For now I don't want to save the diagram persistently. I only save the business model and create a new diagram and its pictogram elements on opening the editor. So I create the new diagram within the loadDiagram Method. After that I create the root object of my business model (called EMFContainer) and link it with the diagram.
	public Diagram loadDiagram(URI uri) {
		Diagram diagram = Graphiti.getPeCreateService().createDiagram("infinica_process_engine_designer", uri.toString(), true);
EMFContainer c = ContainerFactory.eINSTANCE.createEMFContainer();
		PictogramsFactory pictogramsFactory = PictogramsFactory.eINSTANCE;
		PictogramLink link = pictogramsFactory.createPictogramLink();
		diagram.setLink(link);
		link.getBusinessObjects().add(c);
This method is executed correctly and the editor opens, but the pictogram elements I add afterwards, don't appear. This is only a temporary solution, but I don't see, why it should not work.
Here are also my DiagramEditor, DiagramEditorInput and DiagramBehavior classes, if thats any help.
public class InfinicaEditor extends DiagramEditor
	public static final String DIAGRAMID = "infinica_process_engine_designer.InfinicaDiagramType";
	public static final String EDITOR_ID = "infinica-process-engine-designer.editor.InfinicaEditor";
	protected DiagramEditorInput convertToDiagramEditorInput(IEditorInput input)
			throws PartInitException
		if(input instanceof IURIEditorInput)
			return createNewInfinicaEditorInput((IEditorSite) getSite(), (IURIEditorInput) input);
		else
			return super.convertToDiagramEditorInput(input);
	private DiagramEditorInput createNewInfinicaEditorInput(IEditorSite site,
			IURIEditorInput input)
		URI uri = URI.createURI(input.getURI().toString());
		InfinicaDiagramEditorInput infinput = new InfinicaDiagramEditorInput(uri);
		return infinput;
	protected InfinicaDiagramBehavior createDiagramBehavior()
		return new InfinicaDiagramBehavior(this);
public final class InfinicaDiagramEditorInput extends DiagramEditorInput {
	private URI uri;
	public InfinicaDiagramEditorInput(URI uri)
		super(uri, InfinicaEditor.DIAGRAMID);
		this.uri = uri;
	public URI getUri()
		return uri;
	public void updateUri(URI uri)
		this.uri = uri;
public class InfinicaDiagramBehavior extends DiagramBehavior
	public InfinicaDiagramBehavior(IDiagramContainerUI diagramContainer)
		super(diagramContainer);
	protected DefaultPersistencyBehavior createPersistencyBehavior() {
		return new InfinicaPersistencyBehavior(this);
Re: Creating a new Diagram [message #1080046 is a reply to message #1079905] Mon, 05 August 2013 11:59 Go to previous messageGo to next message
Thomas,
maybe this is just missing from the code snippets you sent, but where do you
add the diagram you create in loadDiagram() to the resource set/editing
domain of the editor? The diagram needs to be part of a resource the editor
knows to be able to show it.
Michael
Re: Creating a new Diagram [message #1080878 is a reply to message #1072355] Tue, 06 August 2013 13:39 Go to previous message
Thank you very much Michael,
I finnally found the cause of my problem. "a resource the editor knows" was the tip I needed. My diagram was added to a resource and an editing domain, but they had no connection to the editor. I fixed that and now it works fine.
After this problem is out of the way, I already have another one:
I used the method "link(PictogramElement, BusinessObject)" of the feature provider in a few places, in order to link my Pictogram Elements. Now I realised that it is not working anymore and I have no idea why. The method is called and executed correctly as far as I can tell, but the link, that should be created doesn't exist afterwards.
I need this method because I have non-EMF objects and it uses an independenceSolver for linking them.
So I either need to find out, why the link method of my featureProvider isn't working or I need a new method that is able to link a PictogramElement with a non-EMF object (with or without an independenceSolver)
I hope someone can help me out with this.
Thank you.
[Updated on: Tue, 06 August 2013 13:41]
Report message to a moderator
Previous Topic:Simple gradient
Next Topic:Connections inside ContainerShapes
Current Time: Wed Sep 23 11:04:59 GMT 2020
Powered by FUDForum. Page generated in 0.02164 seconds
