Eclipse crashing on start [message #1072109] |
Mon, 22 July 2013 04:43 |
d grin Messages: 12 Registered: June 2012 |
I have the newest version of the ADT bundle and everything was working fine for a while until today. Now whenever I open eclipse I get "an error has occured. See the log file...". Here is the log file contents -
!SESSION 2013-07-22 00:32:26.946 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=1.7.0_17
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.core.resources 4 566 2013-07-22 00:32:28.264
!MESSAGE Cannot set lower sequence number for root (previous: 26, new: 24). Ignoring the new value.
!STACK 0
java.lang.IllegalArgumentException: Cannot set lower sequence number for root (previous: 26, new: 24). Ignoring the new value.
at org.eclipse.core.internal.resources.SaveManager$MasterTable.put(SaveManager.java:51)
at java.util.Properties.load0(Unknown Source)
at java.util.Properties.load(Unknown Source)
at org.eclipse.core.internal.resources.SaveManager.restoreMasterTable(SaveManager.java:830)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:685)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1528)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2502)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2251)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:439)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
!ENTRY org.eclipse.core.resources 4 566 2013-07-22 00:32:28.265
!STACK 0
!ENTRY org.eclipse.core.resources 4 566 2013-07-22 00:32:28.266
!STACK 0
!ENTRY org.eclipse.core.resources 2 10035 2013-07-22 00:32:28.278
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.osgi 4 0 2013-07-22 00:32:28.313
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (76).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/Meacrux/bin/classes/com/meacrux/MeacruxActivity$2.class' not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:257)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:585)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:50)
at org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDelta(NoDataDeltaNode.java:59)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:47)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:88)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:816)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:815)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:792)
at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:518)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:710)
... 29 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-07-22 00:32:28.332
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (76).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 14 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 23 more
... 29 more
Now I cant really make heads or tails of that, but I did notice a few things. First, there is a file called MeacruxActivity$2.class in the exact directory where it should be. I dont know why its saying its not found. Second, when I open my other installation of eclipse (Juno) which has a different working space (I think, not 100% sure) I get the same error message in the same log file. What is wrong? There are also other people running instances of Eclipse viewing the same project stuff, potentially at the same time. Is it possible this is the cause?
FUDForum. Page generated in 0.03354 seconds
