Re: Copy And Paste of graphical Elements [message #1096636 is a reply to message #1077141] |
Wed, 28 August 2013 17:06 |
Rahul Dev Mishra Messages: 11 Registered: July 2013 Location: Bangalore, India |
Hello All,
Now I have got another issue.
I copy a graphical element from an editor and paste it in another editor. Now when I do that I receive IllegalStateException.
Quote:!MESSAGE GFCommandStack.execute(Command) java.lang.IllegalStateException: Cannot modify resource set without a write transaction
!STACK 0
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:284)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:240)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at com.sap.ndb.studio.view.model.view.impl.ViewNodeImpl.setLayout(ViewNodeImpl.java:263)
at com.sap.ndb.studio.view.model.view.impl.ViewNodeImpl.eUnset(ViewNodeImpl.java:424)
at com.sap.ndb.studio.view.model.view.impl.ProjectionImpl.eUnset(ProjectionImpl.java:163)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eUnset(BasicEObjectImpl.java:1154)
at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.process(FeatureChangeImpl.java:544)
at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.apply(FeatureChangeImpl.java:518)
at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.apply(FeatureChangeImpl.java:493)
at org.eclipse.emf.ecore.change.impl.ChangeDescriptionImpl.apply(ChangeDescriptionImpl.java:300)
at org.eclipse.emf.transaction.util.CompositeChangeDescription.apply(CompositeChangeDescription.java:104)
at org.eclipse.emf.transaction.impl.TransactionImpl.doRollback(TransactionImpl.java:570)
at org.eclipse.emf.transaction.impl.TransactionImpl.rollback(TransactionImpl.java:547)
at org.eclipse.emf.workspace.AbstractEMFOperation.rollback(AbstractEMFOperation.java:630)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:187)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.graphiti.ui.internal.editor.GFCommandStack.execute(GFCommandStack.java:138)
at org.eclipse.graphiti.ui.internal.action.CustomAction.executeOnCommandStack(CustomAction.java:65)
at org.eclipse.graphiti.ui.internal.action.CustomAction.run(CustomAction.java:60)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
However if I paste the graphical element in the same editor, then without any exception the paste action is successful. However pasting the graphical element in some other editor throws an exception as shown above.
Also the paste action happens within a TransactionalEditingDomain.
Could you please let me know where am I going wrong ?
Thanks & Regards,
Rahul
[Updated on: Wed, 28 August 2013 17:07] Report message to a moderator
FUDForum. Page generated in 0.02738 seconds
