Home » Modeling » TMF (Xtext) » Xtext Validation Error
Xtext Validation Error [message #1070992] Fri, 19 July 2013 05:24 Go to next message
Low Coupling is currently offline Low CouplingFriend
Member
I have a DSL with the possibility to import element from other files.
while I am typing the uri of the imported file an error message continuously pops up warning me the typed uri is not valid. Is there any way to fix it?
thank you
Re: Xtext Validation Error [message #1071070 is a reply to message #1070992] Fri, 19 July 2013 09:27 Go to previous messageGo to next message
Yueming Hong is currently offline Yueming HongFriend
Member
Maybe you need to give more details about your grammar (validator if you have changed it).
I am also new hand in xtext. I guess there might be some ambiguity in your grammar then the uri you typed in was recognized as other Eobject(in other rule but nor uri).
I hope this might help.
Re: Xtext Validation Error [message #1071458 is a reply to message #1071070] Sat, 20 July 2013 06:22 Go to previous messageGo to next message
Member
here is the definition of the Import nonterminal element:
Import :
     'import' importURI=STRING
it is the only element in the grammar starting with 'import'
this is the complete error
An internal error occurred during: "Xtext validation".
java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri ../folder
where ../folder is the path I was typing.
Consider that when I finish to write the path everything works fine
Re: Xtext Validation Error [message #1071501 is a reply to message #1071458] Sat, 20 July 2013 09:01 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi so you want to disable this completely. Have a Look at the Workflow of the languAge or the validator. Importurivalidator Must be Activated Somewhere there
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Xtext Validation Error [message #1071999 is a reply to message #1071501] Sun, 21 July 2013 20:55 Go to previous messageGo to next message
Member
hi Christina,
the function is in principle useful. The problem is that it checks the uri while I am still writing it, which is annoying. Also it would be better if the wrong uri was underlined in red as a syntactical error instead of the dialog that pops up.
 // java-based API for validation
                fragment = validation.JavaValidatorFragment {
                    //composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
                    composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
The ImportUriValidator is already commented. So there has to be something else
Re: Xtext Validation Error [message #1072004 is a reply to message #1071999] Sun, 21 July 2013 21:04 Go to previous messageGo to next message
Hi then copy and paste the code to your validator and use
@Check(CheckType.NORMAL) to check only on save (or type faster so
that the check will not be triggered ;-))
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Xtext Validation Error [message #1211477 is a reply to message #1072004] Tue, 26 November 2013 13:05 Go to previous messageGo to next message
anudeep arya is currently offline anudeep aryaFriend
Member
Did anyone get the solution for this.i need the solution ,i am having the same problem now:)
Re: Xtext Validation Error [message #1211509 is a reply to message #1211477] Tue, 26 November 2013 13:23 Go to previous messageGo to next message
i posted the solution before
Re: Xtext Validation Error [message #1213172 is a reply to message #1211509] Wed, 27 November 2013 06:04 Go to previous messageGo to next message
Member
I don't want the error to come on save(Even if there is an empty URI),it is annoying.Can i somehow disable the entire import validation. As mentioned already i tried commenting importURI validation
but this doesn't help me .I want the validation to be disabled so that i can provide some custom validations myself in java validator
Re: Xtext Validation Error [message #1213332 is a reply to message #1213172] Wed, 27 November 2013 07:38 Go to previous messageGo to next message
Sure you reran the workflow and don't hook in the validator yourself?
Eg via @ComposedChecks?
Creating a new example from scratch works for me
Which Xtext version so you use?
Re: Xtext Validation Error [message #1213793 is a reply to message #1213332] Wed, 27 November 2013 11:53 Go to previous messageGo to next message
Member
Yes i reran the workflow after commenting importvalidator.
i didn't understand what do you mean by @ComposedChecks..can you please brief it
i use XTEXT SDK 2.2.1
Anudeep
Re: Xtext Validation Error [message #1213818 is a reply to message #1213793] Wed, 27 November 2013 12:00 Go to previous messageGo to next message
I will see if I find the time to test with that version. Did you
search for refs of the validator? Where is it used?
Re: Xtext Validation Error [message #1213868 is a reply to message #1213818] Wed, 27 November 2013 12:31 Go to previous messageGo to next message
Member
The refs of validation.JavaValidatorFragment is used in my mydslJavaValidator class to highlight the errors in my XEXT editor.
I donot know if that answers your question Razz
Re: Xtext Validation Error [message #1214118 is a reply to message #1213868] Wed, 27 November 2013 14:53 Go to previous messageGo to next message
I asked about the usage of importurivalidator class
Re: Xtext Validation Error [message #1215926 is a reply to message #1214118] Thu, 28 November 2013 08:50 Go to previous messageGo to next message
Member
Actually i have my mydslImportvalidator class in fragment validation.JavaValidatorFragment and this mydslImportValidator extends org.eclipse.xtext.validation.ImportUriValidatorvalidator also i have written custom validations for imports in mydslImportValidator.It is not used explicitly anywhere else.
Anudeep
Re: Xtext Validation Error [message #1215945 is a reply to message #1215926] Thu, 28 November 2013 08:58 Go to previous messageGo to next message
Sorry I don't understand what's your problem then
Re: Xtext Validation Error [message #1215990 is a reply to message #1070992] Thu, 28 November 2013 09:22 Go to previous message
Aaron Digulla is currently offline Aaron DigullaFriend
@Christian: His problem is that Eclipse *shows a dialog box*
@anudeep arya
Xtext shouldn't display a dialog when you type. All validation problems go into the problems view.
The reason why you get a dialog isn't validation, it's that there is an *exception* while the validation runs.
Fix the exception and you should get the default red underline as you type.
Previous Topic:Deleting unused dependencies in Eclipse
Next Topic:[Xtext 2.4.1] Register parser without file extension
Current Time: Tue Jan 26 06:58:08 GMT 2021
Powered by FUDForum. Page generated in 0.02504 seconds
