How to properly integrate Jubula with Jenkins [message #1069893] |
Tue, 16 July 2013 20:35 |
Jiajian Lei Messages: 36 Registered: June 2013 |
Member |
I have followed exactly what this tutorial tells me to, http://devnotesblog.wordpress.com/2011/06/14/automating-eclipse-jubula-tests-with-jenkins/
I was able to run the jubula from command line with the second command shell, which is shown below. But after I created a new job on Jenkins and followed the steps like it says, and created two command shell
first shell: rm -rf /var/opt/teradata/workspace_jubula/testresults/*; mkdir -p /var/opt/teradata/workspace_jubula/testdata; mkdir -p /var/opt/teradata/workspace_jubula/testresults
second shell: testexec -project ggdb_product -version 1.0 -testsuite Project_create_delete -server localhost -port 60000 -autconfig "AUT GGDB@localhost" -datadir /var/opt/teradata/workspace_jubula/testdata -resultdir /var/opt/teradata/workspace_jubula/testresults -language en_US -dbscheme "Default Embedded (H2)" -dbuser sa -dbpw ""
Of course it didn't work.
Since the jubula test project is stored in a database, which in this case I am using a local default Embedded database that comes with Jubula originally, how am I supposed to check in the jubula test projects onto Jenkins. The workspace for the new Jubula job on Jenkins is currently empty. How should I check in the jubula test projects? What kind of files do I need to check in? Do I need to check in the AUT product as well? I am very confused how to integrate with Jubula with Jenkins right now.
Please help.
This is the console output on Jenkins:
Building remotely on sdll3770.labs.teradata.com in workspace /var/opt/teradata/workspace_jubula
[workspace_jubula] $ /bin/sh -xe /tmp/hudson2909594730629373665.sh
+ rm -rf '/var/opt/teradata/workspace_jubula/testresults/*'
+ mkdir -p /var/opt/teradata/workspace_jubula/testdata
+ mkdir -p /var/opt/teradata/workspace_jubula/testresults
[workspace_jubula] $ /bin/sh -xe /tmp/hudson9195538085595282060.sh
+ testexec -project ggdb_product -version 1.0 -testsuite Project_create_delete -server localhost -port 60000 -autconfig 'AUT GGDB@localhost' -datadir /var/opt/teradata/workspace_jubula/testdata -resultdir /var/opt/teradata/workspace_jubula/testresults -language en_US -dbscheme 'Default Embedded (H2)' -dbuser sa -dbpw ''
/tmp/hudson9195538085595282060.sh: line 2: testexec: command not found
Build step 'Execute shell' marked build as failure
Finished: FAILURE
[Updated on: Tue, 16 July 2013 20:48] Report message to a moderator
FUDForum. Page generated in 0.02992 seconds
