Home » Eclipse Projects » Eclipse 4 » Add Composite On Coolbar
Add Composite On Coolbar [message #1068190] Fri, 12 July 2013 15:28 Go to next message
cenk Mising name is currently offline cenk Mising nameFriend
How can I add the composite to on coolbar. We can add it with eclipse 3.7. But with eclipse 4.3 we cannot work same code. We cannot add composite to coolbar with 4.3.
Is it possible. I hope we can find a solution?
Best Regards,
Re: Add Composite On Coolbar [message #1069115 is a reply to message #1068190] Mon, 15 July 2013 07:26 Go to previous messageGo to next message
Jonas Helming is currently offline Jonas HelmingFriend
did you just change the target of you application? Are you therefore
using the compatibility layer or did you migrate to a pure Eclipse 4
application?
Jonas
Am 12.07.2013 17:28, schrieb cenk Mising name:
> Hello,
> Best Regards,
Re: Add Composite On Coolbar [message #1070240 is a reply to message #1069115] Wed, 17 July 2013 14:22 Go to previous message
I didn't do one of them?! How can I it. I wish you can give little information about your solution
BR,
Previous Topic:ILabelDecorator in e4
Next Topic:E4 Tools Internationalization - Use case on OSGi Level
Current Time: Tue Apr 16 09:52:40 GMT 2024
Powered by FUDForum. Page generated in 0.42951 seconds
