Home » Archived » BIRT » how to crab series value in report
how to crab series value in report [message #1068180] Fri, 12 July 2013 10:32 Go to next message
Hi, am currently doing report with series i dono how to crab series value for my requirement and how to compute for this report
for example :
All, 2011, 2012, 2013 are in check box how can i get by clicking check box for chart Report?
i have attached model sampledb
kindly support for this report...
Re: how to crab series value in report [message #1068300 is a reply to message #1068180] Fri, 12 July 2013 18:48 Go to previous messageGo to next message
If you're writing script in the chart, there is the beforeDrawSeries function within the chart script that has easy access to the series, from which you can grab the series identifier. Can you explain more specifically what you're trying to do?
Re: how to crab series value in report [message #1068372 is a reply to message #1068180] Sat, 13 July 2013 00:31 Go to previous messageGo to next message
thank for reply sir my report having more series like 2011,2012,2013 series and now i have to get value series and show/hide series by onclick function of check boxx
for example:
i have check box for All,2011,2012,2013 so now i can select any of this for my requirement
how can i do this...kindly provide sample db for this...
thank in advance
[Updated on: Sat, 13 July 2013 00:39] by Moderator
Re: how to crab series value in report [message #1068385 is a reply to message #1068372] Sat, 13 July 2013 01:30 Go to previous messageGo to next message
Working on similar thing, a sample database would be good for me too. Thanks.
Re: how to crab series value in report [message #1069218 is a reply to message #1068385] Mon, 15 July 2013 08:42 Go to previous messageGo to next message
kindly reply for this post........
thank in advance
Re: how to crab series value in report [message #1070248 is a reply to message #1069218] Wed, 17 July 2013 10:43 Go to previous messageGo to next message
i have got solution for this...
Re: how to crab series value in report [message #1071251 is a reply to message #1070248] Fri, 19 July 2013 12:40 Go to previous message
4040 4040, sorry for the delay. Glad you found a solution.
Asif, do you still need a sample? Let me know your version and your exact issue, if you do.
Previous Topic:Can't load the Query
Next Topic:Can Birt 4.2.2 work on CentOS 6.4?
Current Time: Thu Apr 24 16:20:45 EDT 2025
Powered by FUDForum. Page generated in 0.03704 seconds
