Re: How to get OCL variable from Java code [message #1068186 is a reply to message #1068174] |
Fri, 12 July 2013 14:48 |
Ed Willink Messages: 7669 Registered: July 2009 |
The OCL tooling is all implemented with Java so you can certainly call
it, but the whole point of modeling is to abstract away from the Java,
so if as a novice you are already reaching for java, I strongly suspect
that you are either doing something foolish or have assumed that I
actually understood your very vague original question.
Ed Willink
On 12/07/2013 15:17, zernadji tarek wrote:
> Thanks for your response.
> I'm afraid that i'm not really experienced with OCLinEcore editor and
> also novice in the domain, but i'm investigating your solution which i
> find interesting.
> However, i did not understand what do you mean by "not trivially
> callable by Java.", i want to test the first solution for now, you
> mean that it is not possible to call it from Java code as i mentioned
> in my previous post: int var= result of OCL operation call
> Thanks in advance.
FUDForum. Page generated in 0.04568 seconds
