Re: Schema creation slow with informix [message #1067886 is a reply to message #1067812] |
Thu, 11 July 2013 06:28 |
Oliver Pfau Messages: 9 Registered: November 2011 |
The execution of the eclipselink create table statement took 3 ms if executed manually. The table creation works (but very slow), the insertion works, but the select does not work:
Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query. Error was: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
Call: SELECT ID, MIME_TYPE, TYPE FROM CONTENT_TYPE
08:18:12,301 INFO [stdout] (http--0.0.0.0-9090-6) Query: ReadAllQuery(referenceClass=ContentTypeEntity sql="SELECT ID, MIME_TYPE, TYPE FROM CONTENT_TYPE").
08:18:12,302 INFO [stdout] (http--0.0.0.0-9090-6) [EL Warning]: 2013-07-11 08:18:12.301--UnitOfWork(59195133)--Thread(Thread[http--0.0.0.0-9090-6,5,main])--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DatabaseException
08:18:12,303 INFO [stdout] (http--0.0.0.0-9090-6) Internal Exception: com.ibm.db2.jcc.am.SqlException: [jcc][t4][2093][11302][4.14.111] Die Abfrageverarbeitung wurde wegen eines Fehlers auf dem Server beendet. ERRORCODE=-4228, SQLSTATE=null
08:18:12,304 INFO [stdout] (http--0.0.0.0-9090-6) Error Code: -4228
FUDForum. Page generated in 0.02944 seconds
