Home » Archived » EMF-IncQuery » Error executing EValidator
Error executing EValidator [message #1067714] Wed, 10 July 2013 09:30 Go to next message
Jan Reimann is currently offline Jan ReimannFriend
After a workspace build I get "Error executing EValidator" for two of my
query files. What is this supposed to mean?
best regards,
Jan
Re: Error executing EValidator [message #1067715 is a reply to message #1067714] Wed, 10 July 2013 09:34 Go to previous messageGo to next message
Zoltan Ujhelyi is currently offline Zoltan UjhelyiFriend
Hi Jan,
this means one of our validators have thrown an unexpected exception. This is more then likely a bug in our validators (it might be some issue with your input too, but our validators should not throw unhandled exceptions). Could you look at the Error log view for an exception trace?
Zoltán
Re: Error executing EValidator [message #1067731 is a reply to message #1067715] Wed, 10 July 2013 10:28 Go to previous messageGo to next message
Hi Zoltan,
I get the following trace. But I cannot really understand it because my
project is open.
best regards,
Jan
java.lang.IllegalArgumentException: Invalid project org.myproject.test.
Only existing, open plug-in projects are supported by the generator.
at
com.google.common.base.Preconditions.checkArgument(Preconditions.java:88)
at
org.eclipse.incquery.tooling.core.project.ProjectGenerationHelper.checkBundleDependency(ProjectGenerationHelper.java:267)
at
org.eclipse.incquery.patternlanguage.emf.ui.validation.GenmodelBasedEMFPatternLanguageJavaValidator.checkImportDependency(GenmodelBasedEMFPatternLanguageJavaValidator.java:122)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at
org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:115)
at
org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:292)
at
org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:66)
at
org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:127)
at
org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:171)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:158)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
at
org.eclipse.xtext.validation.CancelableDiagnostician.validate(CancelableDiagnostician.java:36)
at
org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:181)
at
org.eclipse.xtext.validation.CancelableDiagnostician.doValidateContents(CancelableDiagnostician.java:48)
at
org.eclipse.xtext.xbase.validation.XbaseDiagnostician.doValidateContents(XbaseDiagnostician.java:46)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:161)
at
at
at
org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:185)
at
at
at
at
at
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:120)
at
org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:141)
at
org.eclipse.xtext.xbase.annotations.validation.DerivedStateAwareResourceValidator.validate(DerivedStateAwareResourceValidator.java:33)
at
org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:99)
at
org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.addMarkers(DefaultResourceUIValidatorExtension.java:60)
at
org.eclipse.xtext.ui.validation.DefaultResourceUIValidatorExtension.updateValidationMarkers(DefaultResourceUIValidatorExtension.java:45)
at
org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.processDelta(MarkerUpdaterImpl.java:72)
at
org.eclipse.xtext.builder.builderState.MarkerUpdaterImpl.updateMarkers(MarkerUpdaterImpl.java:57)
at
org.eclipse.xtext.builder.builderState.AbstractBuilderState.updateMarkers(AbstractBuilderState.java:80)
at
org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:262)
at
org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:111)
at
org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:184)
at
org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:210)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:89)
at
org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at
org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at
org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Zoltan Ujhelyi wrote:
> Hi Jan,
> Zoltán
Re: Error executing EValidator [message #1067737 is a reply to message #1067731] Wed, 10 July 2013 11:33 Go to previous messageGo to next message
I would like to ask whether your project is an eclipse plug-in project? If you have created it using the EMF-IncQuery project wizard, then it should be (the wizard creates an IncQuery project that is both a Java project and an Eclipse plug-in project).
However, the message and the trace does not make sense otherwise (the editor must be open from a project that is not closed).
Zoltán
Re: Error executing EValidator [message #1067756 is a reply to message #1067737] Wed, 10 July 2013 13:05 Go to previous message
Thx Zoltán,
my project was no plugin project since it's only for some testing. I
converted it and now the error isn't thrown anymore.
best regards,
Jan
> Cheers,
> Zoltán
Previous Topic:After each workspace build every pattern has the same error
Next Topic:Different Results when usin API in runtime Eclipse and in JUnit Plugin Test
Current Time: Sat Sep 26 22:34:28 GMT 2020
Powered by FUDForum. Page generated in 0.02293 seconds
