How does Jubula assert the result? [message #1067666] |
Tue, 09 July 2013 22:28 |
Jiajian Lei Messages: 36 Registered: June 2013 |
Member |
If I want to test the project creation functionality, and I use the capture and record feature to generate the test specifications for the test case. It seems like Jubula only checks if the "New Project" is closed after I click on the "finish" button. If the window is closed, then the test passes. But it doesn't verify if the project is actually created in the Package Explorer. How do I add such test specification, or how to make the recorder to generate it?
Similarly, say if I want to test the variable view. The capture and record feature helps me to generate the test specifications for performing the actions of adding/removing/editing the variables, but it doesn't generate the test specifications to verify the result within variable view, i.e., whether or not the adding/removing/editing actions have really been triggered.
How does Jubula work in terms of verifying the content inside a view, like the projectTree in Package Explorer, variable names/values in variable view and expression view, or even content(source code) in text editor?
FUDForum. Page generated in 0.04018 seconds
